  1. Можно через переходник. Автофокус потеряете.
  2. на Фотокине ожидается презентация Olympus 40-150 /2.8
    Вес стекла будет - чуть меньше килограмма, длинна 16см. В комплекте бленда (бывает олимпус ее зажимает), пыле/влаго/морозоустойчив. Корпус метал.
    http://www.43rumors.com/precision-camera-discloses-full-olympus-40-150mm-lens-details/
  3. Красава. По слухам еще будет комплект с экстендером 1.4. Нахрена я 75300 покупал?...
  4. #6484 15 сен 2014 в 09:18 | Всё о системе Micro Four Thirds System (Olympus, Panasonic и д.р.) | Страница 325
    ну тогда ты о микре не думал :) да и думаю в некоторых случаях картинка с а99+70-400 будет в большем выигрыше.... хотя опять же какие задачи ставить...
    И по слухам в новой прошивке для ем1:
    -Image display time lag: 16 msec (frame rate setting is high speed)
    -Multiple simultaneous settings now available in Live Guide
    - Exposure compensation (±3 EV) is now available in HDR 1/HDR2 shooting
    - A function was added to cancel Color Creator and return to the original Picture Mode by pressing the MENU button when using Color Creator function
    - Even when Art Filter is set for the Picture Mode in movie shooting, the Movie Tele-converter can now be used
    - AF function for each frame was added to Custom Self Timer. In Drive Mode’s Custom Self Timer settings, you can now press the INFO button to change settings
    - MF Assist is now supported in magnified frame position
    - 3x has been added to high resolution magnified Live View
    - The Peaking display frame rate has been improved
    - Electronic zoom speed setting function was added. An icon appears on the LCD monitor when using the olympus zoom lens
    - When the arrow pad is set to Direct function, the Underwater/Underwater macro functions can be used with the left and down button on the arrow pad
    - Double tap is now supported in touch operations on the Super Control Panel
    - The level gauge and histogram can now be displayed during magnified frame display. The Touch Off icon was added to magnified frame display
    - A function was added so that shooting information recorded in HDR1/HDR2 can be viewed in the playback screen
    - Information on composited number of shots for images recorded with Live Composite was added (Can be checked in Olympus Viewer3)
    - When the BKT button is pressed for seconds, the BKT menu now appears
    -Keystone Compensation (Digital Shift)
    -Tethered Shooting System (OLYMPUS capture)
    -Live Composite
    -Zoom In/Out and Layout have been added to Photo Story. Save (complete partway through), Temporary Save, and Resume functions have been added to Photo Story mode
    -New Art Filter: Vintage and Partial color
    -Old film effect
    - The Aperture Lock function has been added to Aperture Preview
    - The Panning Shot shooting mode has been added to SCN mode
    Пока писал и зефирку фоткал - на оф сайте выложили прошивку под ем1 2.0 - скачиваем и ставим :)
    http://www.olympus.com.ru/site/ru/c/cameras_support/downloads/e_m1_download.html
  5. Теперь еще осталось для петерочки прошивки с пикингом дождаться... вроде обещали...
  6. Размер ... размер ! Уверен , это будет отличный объектив , но его с тушкой в маленькую напузную сумочку не засунешь . В отличии от ЕПЛ-5+панаблин :) . Из сегодняшних скачек по Риге и окрестностям .
    cdx нравится это.
  7. ну панас 35-100/2.8 более компактен :) выбор есть :)
  8. Микроводы! А что скажете про olympus ed 9-18 ? Как у него с углами на открытой? Я так понял их есть 2 штуки под разный олимпусовский байонет. А переходник есть на микру?
  9. Да я все забываю , что для большинства на этой ветке Олик основная камера . А в таком случае размеры объективов очень даже гуманны , по сравнению с Тёткой :).
    Примеры впечатляющие . А почему много где указано 210мм ?
  10. Это с конвертером 1,4х.
  11. А, точно ! Он же в комплекте идет .
  12. Насколько я понял, можно купить комплект с конвертером и без. И можно отдельно купить конвертер.
  13. За сто то лишних евро мало кто , поди, откажется ...
  14. Да, их два. Под просто 4/3 и под микро 4/3. Тот, что под микру, совсем крохотный и лёгкий на него можно накручивать фильтры и картинка с него хорошая и по углам резок. Есть ещё ширик от панаса 7-14F4, отличный объектив, но фильтры не накрутишь, у него встроенная бленда и выпуклая как у фишая передняя линза, геометрия исправлена и резкость по всему полю отменная, но дорогой. А переходники с 4/3 на микру и обратно есть нескольких видов и производителей.
  15. Спасибо большое! Блин, а я губу сначала раскатал, на ебей за 13000 лежит, но на 4/3, а на микру уже от 20000. Тут уже начинаю задумываться: а что лучше sel 10-20 или олик 9-18. Постоянная 4 на sel - это плюс, шире, это тоже плюс? да и стаб в нём имеется. Цена одинаковая. А если брать sel, то тогда и микра не очень нужна, если только под птичек панасоник 100-300, тут я понимаю без альтернатив за эту цену?
  16. у меня был 9-18 микрушный. Хорошее стеклышко, маленькое и довольно резкое. Но с покупкой 12-40, взял себе фишай самьянг 7.5мм, после выравнивания дает угол не уже 9мм. микрушный 9-18 торгуется на барахолках по 15-17т, но редкий зверь...
  17. У самьянгов цвет редкостное г. У меня фишай на е-баонет есть от самьянга, резкость норм, но как посмотрю на цвет, в сравнении с шириком от минолты, аж выкинуть хочется. А 12- 40 мм на микре мне ни туда, ни сюда. На барахолке 9-18 пока дешевле 17 не видел. Или есть хитрые олимпусовские барахолки?
