Не для нексоводов это не нужно. Это нужно тем у кого куча старых никоновских стекол! А их много и есть суперские! ну размеры...., f mount flange disntace обязывает, зато никаких тебе cyan shift и прочего! кстати - пентапризма полностью зеркальная! если верить слухам! Это не пластиковые побрекушки в модных пластиковых зеркалках. Все фотки камеры со всех углов http://nikonrumors.com/2013/11/04/this-is-the-nikon-df.aspx/ 16МП на ФФ.. это круто на самом деле. Because of the number of posts I published in the past few weeks on the upcoming Nikon DF camera, many readers have missed some of the rumored specifications. Here is a recap of what we know so far - if you have some additional information, you can contact me anonymously here: The new camera will be called Nikon DF which stand for "Digital Fusion" Nikon FM2 like design, but with a larger pentaprism Most likely be available in two colors - all black and silver/black (a.k.a. as Panda version) Standard Nikon F-mount Pentaprism viewfinder (meaning the camera will not be mirrorless) 16.2MP 36x23,9 full frame sensor (same as in the D4?) The AF system of the Nikon DF will be most likely the same as in the D610 with 39 points SD memory card 2016-pixel RGB image sensor 9-cell framing grid display 3D color matrix metering II Native ISO range: 100-12,800 (incl. ISO 50 and ISO 102,400) 5.5 fps for up to 100 shots 3.2" LCD screen Expeed 3 processor Battery:EN-EL14 Dimensions: 143.5 x 110 x 66.5mm Weight: 765g No video recording capabilities The camera will meter even with non-AI lenses down to full aperture The camera will ship with a new special edition Nikkor 50mm f/1.8G lens to match the look/design of the body The camera will have physical controls and excellent build quality (which explains the 765g weight) Nikon calls it a "hybrid" camera - not sure what exactly they mean with that The Nikon DF will have settings for 1:1, 3:2 and 16:9 aspect ratios The announcement will be on November 5th right on time for Le Salon de la Photo show that will take place in Paris (November 7-11, 2013) Read more on NikonRumors.com: http://nikonrumors.com/2013/10/28/nikon-df-camera-rumors-recap.aspx/#ixzz2jhQRR3e7 http://nikonrumors.com/2013/10/28/nikon-df-camera-rumors-recap.aspx/ назад в прошлое:
А вот и ценник на Никон http://www.amazon.com/Nikon-FX-Format-Digital-Camera-Silver/dp/B00GD1KASM/ref=sr_1_4?s=electronics&ie=UTF8&qid=1383591275&sr=1-4&keywords=Nikon+DF
Вам - никаких. Лично для меня - возможность выкинуть D700 и взять на замену вот эту тушку для лоулайта. А для нексоводов Сони что-нибудь может быть и выпустит. Ну там любимые всеми нексоводами стёкла с f4, ещё тушек 10-15 за 2014й год, ещё что-нибудь столь же нужное. А эта тушка она вообще никак не пересекается с беззеркальной темой и обсуждать тут про неё нечего.
Update: The Nikon Df and 50mm f/1.8 kit will cost $2,996.95. The body only is $2,746.96. See the full details on Amazon.com and in this post. Read more on NikonRumors.com: http://nikonrumors.com/2013/11/04/this-is-the-nikon-df.aspx/#ixzz2ji1HHLy9 p.s. Если там замер и модуль АФ от четвёрки, то это значительно более серьёзно, чем оно кажется беззеркальщикам. Это этакая вполне себе революция в зеркальном мире, начинка от топовой тушки по цене середняка. Ну в переводе на беззеркальный, это как если бы Сони выпустила свой A7 со всеми потрохами за цену вдвое ниже текущей. Собственно, это повторение пройденного - D100/D70, D2X/D300, D3/D700, D4/Df. Красиво и предсказуемо. Теперь конкурентам придётся тоже прыгать как Никон говорит. Очень красиво.
Никон какой-то странный получился. Зачем колесо PASM, если там мануальные крутилки? К тому же, на объективах нет кольца диафрагмы, в отличие от фуджика, где крутилки выдержки и экспозиции реально удобные. Поставил выдержку в А, крутишь диафрагму на объективе. А на никоне что крутить? Я лично в 90% случаев снимаю в А, ИСО приходится ставить вручную из-за отсутствия на нексе возможности выставить "потолок" авто-исо.
1. Нормально всё. Куда без колеса, с колесом удобно, достаточно один раз попробовать и тогда уже говорить не о че. Над шуткой об отсутствии на Nikon F оптике кольца диафрагмы я сейчас смеюсь, вот так на всех 60 миллионах стёкол их нет, вообще. И что крутить (внимательно смотрит на привода диафрагмы на всех своих никоновских стёклах), как дальше жить не знаю. 2. Это не для нексоводов, ещё раз. И это удар не по Сони или прочим беззеркалкам. Это плевок, пинок и удар в пах товарищам из Кэнона. Удар очень злой и больной, но опять же, беззеркальщикам это не понять, это не по вашу душу и это не ваша игра. Хотя если только A-маунтерам ещё небольшой пендаль, но всё же по касательной, а-маунтеры это не совсем ЦА Н и К, это что-то своё.
Я так понимаю, это главное качество камер, с точки зрения нексоводов. - А что за камера? - АФ модуль CAM90000, фокусируется за секунду до того, как событие произошло, использую методы квантового предсказания, графеновая матрица с диапазоном в 60 ступеней, оптика из жидкого стекла, 12-300 f1.2, 100% видоискатель с увеличением 1.5. - Стоп-стоп-стоп, а какая у камеры выдержка минимальная? - 1/4000. - Что за говно вы мне тут пытаетесь подсунуть?! Я каждый день снимаю на экваторе в полдень на оптику с f0.95, а оставшееся время в небо тычу стёклами, самолётики ловлю на фоне солнца! Заберите ваше говно, мне такое не нужно! А ISO50, поляры и нейтральники придумали трусы, с этим к гадалке не ходи.
Hellzau, ISO 50 - искусственное. Я такое же исо 50 могу сделать в лайтруме, опустив ползунок экспозиции на 1 стоп. Поляры и нейтральники - это конечно хорошо, но неудобно. Просто обидно, что в D700-D800 есть возможность 1/8000 выставить, а тут нет.
AlexPaul, Да вот фиг его знает, на самом то деле. Есть у меня знакомый никонист, тоже любитель, потихоньку доапгрейдился до д700, на д4 облизывается, но дорого, а д800 не хочет, шибко уж любит на высоких исо снимать. Вот его эта камера может заинтресовать, и именно начинкой.
