Важно Всё о Capture ONE
  1. #1 22 дек 2007 в 14:16 | Важно Всё о Capture ONE | Страница 171
    домашняя страница
    vinograddik нравится это.
  2. [​IMG]
    Capture One обновился до версии 12.1.4
    12.1.4 Camera & Lens Support
    Sony a9 II (*Live-view currently only supported through USB2)
    Sony RX100 VII
    Sony RX0 II
    Sony a6600
    Sony a6100
    Fujifilm X-Pro3
    Fujifilm X-A7
    Leica Q2
    Sony FE 35mm F1.8 (SEL35F18F)
    Sony FE 200-600mm F5.6-6.3 G OSS (SEL200600G)
    Sony FE 600mm F4 GM OSS (SEL600F40GM) Phase One
    Phase One RS 72mm/iXG II Canon
    Canon RF 24-105mm f/4 Leica
    Leica APO-Summicron-SL 1:2/50 ASPH Sigma
    Sigma 35mm F1.4 DG HSM | A (Canon EF)
    12.1.4 Bug Fixes Mac
    Fixed an issue where folders with Swedish characters could cause a database verification failure
    Fixed an issue where color readouts would sometimes not show on MacOS Catalina
    Fixed an issue where EIP files would not be saved correctly with very long file paths
    Fixed an issue where Capture One would inoperable due to a previously deactivated license key
    Fixed an issue with fonts on MacOS Catalina
    Fixed an issue where running the script ‘Get Logs’ would return an error
    Fixed an issue where lens profiles would be unavailable for Fuji S-series cameras
    Fixed an issue where JPEG 2000 files show an error in Adobe Photoshop
    Fixed an issue where Fill Mask would not completely cover the image
    Fixed an issue where processing Sony A7r IV files to DNG would cause a color shift
    Fixed an issue with OpenCL using Radeon VII graphics cards
    12.1.4 Bug Fixes Windows
    Fixed an issue where the crop path would sometimes disappear from thumbnails
    Fixed an issue where the Overlay did not display on Live-View
    Capture One 12.1.4 Release notes
    Прямые ссылки на скачивание:
    Capture One 12.1.4 (Win)
    DmitryM нравится это.
  3. Александр, спасибо, очень полезное видео получилось. Всерьез задумался о переходе.
  4. Вопрос.. может, правда, раньше и задавали или даже я задавал..
    Какая скидка (или сколько %) стоит апгрейд между мажорными версиями?
    просто на данный момент стоимость годовой подписки 180, а полной версии 300 баксов...
    соответственно, если скидка при обновлении меньше 40% - интереснее смотреть на подписку..
    Baikalru нравится это.
  5. И ещё..
    можно ли список объективов для коррекции откорректировать?
    А то используется два, по умолчанию ставит Generic - и надо вручную простыню листать
  6. У кого-нибудь получается подключить A7RIV к Capture One 12 / 20 beta через USB 3 Type-C (обычный и Tether Tools)? У меня ни в какую не хочет, хотя с Imaging Edge всё прекрасно работает.
  7. Разработчики стали рассылать предложения на предзаказ на апгрейд , я тоже заметил , что стоимость по подписке на год , в итоге ниже чем каждый год за апгрейд платить , но за него можно и не платить и остаться на старой версии
  8. В общем да, каждый год не так что б фич новых появляется сразу критично, хотя повышение ценника в прошлый раз был так себе затеей с точки зрения пользователя.
  9. Господа, началась Черная Пятница и Capture One прислали ссылку и промокод на скидку 30 процентов. Совершенно на все продукты, не только Сони.
    С 28 по 1 декабря.
    Как получить:
    1. Переходите по ссылке и выбираете свой тип покупки:
    https://captureone.38d4qb.net/j40Yv
    2. Используйте код BLACK-FRIDAY-19
    Медведев, cdx, nauticus и ещё 1-му нравится это.
  10. Для сонек ценник 90 долларов получается. Очень приятная цена
    Медведев и vinograddik нравится это.
  11. Получается, самое выгодное время обновления - Черная Пятница)))
    Хорошее время экономии))
  12. Эх, поторопился я (
  13. Неплохо ещё приятно, что дают бонус на Capture One Pro 20 Pre-order за 0 $
  14. да, забыл про это написать. Действительно хороший бонус.
    Сегодня последний скидочный день.
  15. Медведев и cdx нравится это.
  16. #3416 4 дек 2019 в 17:20 | Важно Всё о Capture ONE | Страница 171
    Почему же говорят? Вышел. Три часа назад:
    Capture One 20 v. 13.0.0.155
    December 04 th 2019
    Capture One обновился до версии 13.0.0.155
    Capture One is the complete image editing software solution. With powerful tools for organizing, color grading, layer editing, and much more, you have full control of both your images and your workflow.
    • Get accurate colors with custom-made color profiles for 500+ cameras.
    • Fast importing and exporting of image files.
    • Realize your creative vision with the precision and color-editing tools.
    • Instantly capture, view, and edit images with reliable tethered solution.
    • Customizable interface gives you a smooth editing experience.
    • Flexible payment plans – subscribe or own your license.
    Features:
    NEWEST FEATURES AND IMPROVEMENTS
    Capture One 12 delivers better color, faster performance, and more creative control. New features includes advanced masking functionality, an even more efficient and intuitive user experience, plug-in compatibility, and much more.
    IMAGE EDITING
    Capture One has been developed with image quality and ease of use in mind. Every tool is designed to give you full control of all aspects of the editing process - preserving, recovering and optimizing all information from your RAW files. The full range of tools offer extensive possibilities to always achieve perfect results.
    LAYERS
    For precise local adjustment, most tools in Capture One Pro can be applied on layers, improving the control of every image. Apply up to 16 layers and use different brush options for precise masking. Control the impact of your local adjustments by changing the opacity of each layer.
    ORGANIZE YOUR IMAGES
    Asset management is important for every photographer, be it management of images from individual day-to-day jobs or large collections with thousands of images. Capture One offers tools and solutions for every type of photographer, making asset management simple, fast and effective
    WORKFLOW AND PERFORMANCE
    From customizable tools and keyboard shortcuts to graphics acceleration and instant tethered capture; Capture One is built to minimize your workload and maximize your efficiency. Design your own workspace and find your way of working in Capture One.
    COLOR CONTROL
    Capture One is known for its exceptional handling of color. Thanks to our custom camera profiling, every RAW file shines - straight from the camera. Whether you seek creative color grading tools or want to ensure natural colors in your images, Capture One delivers powerful and precise tools to achieve your vision.
    DETAILS AND LENS PROFILES
    With image quality as the driving factor, Capture One is developed to maximize the output of every RAW file, providing the highest level of details possible. Each supported lens applies a custom-made lens profile, providing precise tools for minimizing distortion and light fall-off.
    Changelog (v13.0.0)
    Capture One 20 is a major release of Capture One containing new functionality, improved tools, a better over-all user experience, camera support, performance optimizations, many bug fixes, and general under-the-hood tweaks for all Capture One variants.
    • Scrolling Tools
    • New Basic Color Editor
    • Improved Crop Tool
    • Improved Noise Reduction
    • Improved High Dynamic Range Tool
    • Improved Copy/Apply for Layers
    • Improved DNG support
    • ‘Select Next When’
    • General User Experience changes
    Camera Support
    • Canon
      • Canon 90D
      • Canon M6 II
    • Nikon
      • Nikon Z50
    • Leica
      • Leica V-LUX 5
    • Panasonic
      • Panasonic Lumix DC-S1H
    • Pentax
      • Pentax K-1 II
    • Olympus
      • Olympus E-M5 III
    • Ricoh
      • Ricoh GR III
    • Other
      • Generic GoPro HERO RAW support
    Lens Support
    • Rodenstock
      • RS-23mm/Aerial
    Capture One 20.0.0 Release notes
    WHAT'S NEW
    Прямая ссылка на закачку Capture One 20.0.0 (13.0.0.155) Windows
    Прямая ссылка на закачку Capture One 20.0.0 (13.0.0.155) macOS
    smiserg, Медведев и Alikbars нравится это.
  17. Медведев нравится это.
  18. Триалка теперь требует активации
  19. Все Пользователи 12-ой версии получают бесплатное обновление до 20 версии?
    Или только те, кто ее приобрел в последнее время?
  20. Вот именно они.
