Sony SEL-28F20 - 28mm f2,0 (E-Mount)
Тема в разделе "Автофокусные объективы на Sony NEX: Sony E-mount", создана пользователем Maksimka350, 25 фев 2015.
  1. Ну не надо наговаривать, нет там на исо 4000 )
  2. Да и в мыслях не было, снимок то нормально смотрится.
    ---- ExifTool ----
    ExifTool Version Number : 9.95
    ---- File ----
    File Name : 275628_original.jpg
    Directory : .
    File Size : 467 kB
    File Modification Date/Time : 2015:05:31 21:44:11+03:00
    File Access Date/Time : 2015:05:31 21:43:57+03:00
    File Creation Date/Time : 2015:05:31 21:44:07+03:00
    File Permissions : rw-rw-rw-
    File Type : JPEG
    File Type Extension : jpg
    MIME Type : image/jpeg
    Exif Byte Order : Little-endian (Intel, II)
    Current IPTC Digest : 99b28b96dfafe724d419566840a07e88
    Image Width : 900
    Image Height : 600
    Encoding Process : Baseline DCT, Huffman coding
    Bits Per Sample : 8
    Color Components : 3
    Y Cb Cr Sub Sampling : YCbCr4:4:4 (1 1)
    ---- EXIF ----
    Make : SONY
    Camera Model Name : ILCE-7
    Orientation : Horizontal (normal)
    X Resolution : 300
    Y Resolution : 300
    Resolution Unit : inches
    Software : Adobe Photoshop Lightroom 6.0 (Macintosh)
    Modify Date : 2015:05:29 15:09:07
    Artist : Vadim Ponomarenko
    Copyright : Vadim Ponomarenko
    Exposure Time : 1/1000
    F Number : 14.0
    Exposure Program : Manual
    ISO : 4000
    Sensitivity Type : Recommended Exposure Index
    Recommended Exposure Index : 4000
    Exif Version : 0230
    Date/Time Original : 2015:05:29 12:10:09
    Create Date : 2015:05:29 12:10:09
    Shutter Speed Value : 1/1000
    Aperture Value : 14.0
    Brightness Value : 7.696875
    Exposure Compensation : 0
    Max Aperture Value : 2.0
    Metering Mode : Multi-segment
    Light Source : Unknown
    Flash : Off, Did not fire
    Focal Length : 28.0 mm
    Color Space : sRGB
    File Source : Digital Camera
    Scene Type : Directly photographed
    Custom Rendered : Normal
    Exposure Mode : Manual
    White Balance : Auto
    Digital Zoom Ratio : 1
    Focal Length In 35mm Format : 28 mm
    Scene Capture Type : Standard
    Contrast : Normal
    Saturation : Normal
    Sharpness : Normal
    Lens Info : 28mm f/2
    Lens Model : FE 28mm F2
    Compression : JPEG (old-style)
    X Resolution : 72
    Y Resolution : 72
    Thumbnail Offset : 914
    Thumbnail Length : 19278
    ---- XMP ----
    XMP Toolkit : Adobe XMP Core 5.6-c011 79.156380, 2014/05/21-23:38:37
    Creator Tool : Adobe Photoshop Lightroom 6.0 (Macintosh)
    Modify Date : 2015:05:29 15:09:07+03:00
    Rating : 1
    Metadata Date : 2015:05:29 15:09:08+03:00
    Lens : FE 28mm F2
    Date Created : 2015:05:29 12:10:09
    Document ID : xmp.did:88ad4045-4cca-4dba-94a5-3fdde11565e9
    Original Document ID : 82F24CE49C63A087BBCD6322946DEAEA
    Instance ID : xmp.iid:8213ea00-a16d-4a11-8fb1-100462c21ed4
    Format : image/jpeg
    Web Statement : picturestock.ru
    Marked : True
    Version : 9.0
    Process Version : 6.7
    White Balance : As Shot
    Auto White Version : 134348800
    Incremental Temperature : 0
    Incremental Tint : 0
    Saturation : 0
    Sharpness : 0
    Luminance Smoothing : 0
    Color Noise Reduction : 0
    Vignette Amount : 0
    Shadow Tint : 0
    Red Hue : 0
    Red Saturation : 0
    Green Hue : 0
    Green Saturation : 0
    Blue Hue : 0
    Blue Saturation : 0
    Vibrance : 0
    Hue Adjustment Red : 0
    Hue Adjustment Orange : 0
    Hue Adjustment Yellow : 0
    Hue Adjustment Green : 0
    Hue Adjustment Aqua : 0
    Hue Adjustment Blue : 0
    Hue Adjustment Purple : 0
    Hue Adjustment Magenta : 0
    Saturation Adjustment Red : 0
    Saturation Adjustment Orange : 0
    Saturation Adjustment Yellow : 0
    Saturation Adjustment Green : 0
    Saturation Adjustment Aqua : 0
    Saturation Adjustment Blue : 0
    Saturation Adjustment Purple : 0
    Saturation Adjustment Magenta : 0
    Luminance Adjustment Red : 0
    Luminance Adjustment Orange : 0
    Luminance Adjustment Yellow : 0
    Luminance Adjustment Green : 0
    Luminance Adjustment Aqua : 0
    Luminance Adjustment Blue : 0
    Luminance Adjustment Purple : 0
    Luminance Adjustment Magenta : 0
    Split Toning Shadow Hue : 0
    Split Toning Shadow Saturation : 0
    Split Toning Highlight Hue : 0
    Split Toning Highlight Saturation: 0
    Split Toning Balance : 0
    Parametric Shadows : 0
    Parametric Darks : 0
    Parametric Lights : 0
    Parametric Highlights : 0
    Parametric Shadow Split : 25
    Parametric Midtone Split : 50
    Parametric Highlight Split : 75
    Sharpen Radius : +1.0
    Sharpen Detail : 25
    Sharpen Edge Masking : 0
    Post Crop Vignette Amount : 0
    Grain Amount : 0
    Lens Profile Enable : 0
    Lens Manual Distortion Amount : 0
    Perspective Vertical : 0
    Perspective Horizontal : 0
    Perspective Rotate : 0.0
    Perspective Scale : 100
    Perspective Aspect : 0
    Perspective Upright : 0
    Auto Lateral CA : 0
    Exposure 2012 : 0.00
    Contrast 2012 : 0
    Highlights 2012 : 0
    Shadows 2012 : 0
    Whites 2012 : 0
    Blacks 2012 : 0
    Clarity 2012 : 0
    Defringe Purple Amount : 0
    Defringe Purple Hue Lo : 30
    Defringe Purple Hue Hi : 70
    Defringe Green Amount : 0
    Defringe Green Hue Lo : 40
    Defringe Green Hue Hi : 60
    Convert To Grayscale : False
    Tone Curve Name : Linear
    Tone Curve Name 2012 : Linear
    Camera Profile : Embedded
    Lens Profile Setup : LensDefaults
    Has Settings : True
    Has Crop : False
    Already Applied : True
    Raw File Name : 44.JPG
    History Action : derived*saved*saved
    History Parameters : saved to new location
    History Instance ID : xmp.iid:88ad4045-4cca-4dba-94a5-3fdde11565e9*xmp.iid:8213ea00-a16d-4a11-8fb1-100462c21ed4
    History When : 2015:05:29 15:09:07+03:00*2015:05:29 15:09:08+03:00
    History Software Agent : Adobe Photoshop Lightroom 6.0 (Macintosh)*Adobe Photoshop Lightroom 6.0 (Macintosh)
    History Changed : /*/metadata
    Derived From Document ID : 82F24CE49C63A087BBCD6322946DEAEA
    Derived From Original Document ID: 82F24CE49C63A087BBCD6322946DEAEA
    Creator : Vadim Ponomarenko
    Rights : Vadim Ponomarenko
    Tone Curve : 0, 0*255, 255
    Tone Curve Red : 0, 0*255, 255
    Tone Curve Green : 0, 0*255, 255
    Tone Curve Blue : 0, 0*255, 255
    Tone Curve PV2012 : 0, 0*255, 255
    Tone Curve PV2012 Red : 0, 0*255, 255
    Tone Curve PV2012 Green : 0, 0*255, 255
    Tone Curve PV2012 Blue : 0, 0*255, 255
    ---- Photoshop ----
    X Resolution : 300
    Displayed Units X : inches
    Y Resolution : 300
    Displayed Units Y : inches
    Copyright Flag : True
    URL : picturestock.ru
    Photoshop Thumbnail : (Binary data 19278 bytes, use -b option to extract)
    ---- IPTC ----
    Coded Character Set : UTF8
    Application Record Version : 4
    Time Created : 12:10:09
    Digital Creation Date : 2015:05:29
    Digital Creation Time : 12:10:09
    By-line : Vadim Ponomarenko
    Copyright Notice : Vadim Ponomarenko
    ---- ICC_Profile ----
    Profile CMM Type : Lino
    Profile Version : 2.1.0
    Profile Class : Display Device Profile
    Color Space Data : RGB
    Profile Connection Space : XYZ
    Profile Date Time : 1998:02:09 06:49:00
    Profile File Signature : acsp
    Primary Platform : Microsoft Corporation
    CMM Flags : Not Embedded, Independent
    Device Manufacturer : IEC
    Device Model : sRGB
    Device Attributes : Reflective, Glossy, Positive, Color
    Rendering Intent : Perceptual
    Connection Space Illuminant : 0.9642 1 0.82491
    Profile Creator : HP
    Profile ID : 0
    Profile Copyright : Copyright © 1998 Hewlett-Packard Company
    Profile Description : sRGB IEC61966-2.1
    Media White Point : 0.95045 1 1.08905
    Media Black Point : 0 0 0
    Red Matrix Column : 0.43607 0.22249 0.01392
    Green Matrix Column : 0.38515 0.71687 0.09708
    Blue Matrix Column : 0.14307 0.06061 0.7141
    Device Mfg Desc : IEC http://www.iec.ch
    Device Model Desc : IEC 61966-2.1 Default RGB colour space - sRGB
    Viewing Cond Desc : Reference Viewing Condition in IEC61966-2.1
    Viewing Cond Illuminant : 19.6445 20.3718 16.8089
    Viewing Cond Surround : 3.92889 4.07439 3.36179
    Viewing Cond Illuminant Type : D50
    Luminance : 76.03647 80 87.12462
    Measurement Observer : CIE 1931
    Measurement Backing : 0 0 0
    Measurement Geometry : Unknown
    Measurement Flare : 0.999%
    Measurement Illuminant : D65
    Technology : Cathode Ray Tube Display
    Red Tone Reproduction Curve : (Binary data 2060 bytes, use -b option to extract)
    Green Tone Reproduction Curve : (Binary data 2060 bytes, use -b option to extract)
    Blue Tone Reproduction Curve : (Binary data 2060 bytes, use -b option to extract)
    ---- APP14 ----
    DCT Encode Version : 100
    APP14 Flags 0 : [14], Encoded with Blend=1 downsampling
    APP14 Flags 1 : (none)
    Color Transform : YCbCr
    ---- Composite ----
    Aperture : 14.0
    Date/Time Created : 2015:05:29 12:10:09
    Digital Creation Date/Time : 2015:05:29 12:10:09
    Image Size : 900x600
    Megapixels : 0.540
    Scale Factor To 35 mm Equivalent: 1.0
    Shutter Speed : 1/1000
    Thumbnail Image : (Binary data 19278 bytes, use -b option to extract)
    Circle Of Confusion : 0.030 mm
    Field Of View : 65.5 deg
    Focal Length : 28.0 mm (35 mm equivalent: 28.0 mm)
    Hyperfocal Distance : 1.86 m
    Light Value : 12.3
    Хотя по мне, выше ISO 100 нет необходимости, и этому есть хороший пример.
  3. [​IMG]
  4. weirdo,
    Не томи, давай хозяина лисапеда и на открытой.... тока недавно заявлял одну её родимую признаёшь  :D
     Пейзажи говорил  не твоё, хотя бы что то надо показать ?  :)
    желательно обойтись без кошаков и ботвы.
  5. #45 8 июн 2015 в 21:03 | Sony SEL-28F20 - 28mm f2,0 (E-Mount) | Страница 3
    dgsjsj,
    Доберусь до компа, выложу что нибудь :)
    Постараюсь без кошакоф :)
    upd:
    все добрался, сейчас потихоньку буду разгребать :)
    начнем с открытой :)
    зы
    на открытой контру по бокам и по центру держит - идеально!
  6. Будем считать, что я ничего не понимаю в контре на открытой, не цепляет совсем.
    Можно потихоньку начинать прикрывать не в контре.   <_<
  7. #47 16 июн 2015 в 20:32 | Sony SEL-28F20 - 28mm f2,0 (E-Mount) | Страница 3
    Ну на закрытых не интересно :) Так что тогда ищите примеры на фликере :)
    Я потом че нить сниму на ф8 - ф11 :)
  8. Д а не в крайности не нужно, желательно так как логика сюжета подскажет.  :)
    Мотив покупки фокусного 28 мм? Если не любитель пейзажа, то для ближних планов и семейной хроники?
  9. мне нужен как репортажный фикс в условиях плохой освещенности и необходимости более-менее узкого грип для полноростовых потретов. примеры тут
  10. #50 23 июн 2015 в 10:43 | Sony SEL-28F20 - 28mm f2,0 (E-Mount) | Страница 3
    Это не пейзажное стекло по большому счётуМотив покупки - выше уже ответили ну и добавлю - еще клубы, тесные помещения, портретики жанровые в интерьере есть масса применений у светлого ширика :) мне нравится плавная перспектива например на портретах а это могут дать только короткие и светлые стекла :)
  11. На мой взгляд осмысленно можно снимать всё и не делать себе искусственных ограничений.
    Lexsnd, Конечно владеет инструментом, для своих задач, виртуозно. Похвально. :)
  12. Есть примеры данного стекла на кропе?
    Спасибо.
  13. Хм, странно, стеклышко вроде интересное, а тема какая-то вялая. При чем стеклышко должно быть интересно как ФФ так и кропу. Альтернатив под кроп (а особенно под а6000) я не вижу...
  14. просто имхо кого сабж заинтересовал настолько, что он захотел попробовать - тот купил и снимает, как ни в чем не бывало) тыц
  15. #55 7 авг 2015 в 13:26 | Sony SEL-28F20 - 28mm f2,0 (E-Mount) | Страница 3
    Видите-ли, F2.0, для такого фокусного, это как бы помягче сказать? Ну, для очень креативного товарисча или городского сумашедшего гика, наверное. По большому счёту достаточно 3,5, например таких как у такумаров или зуйков... :) А покупать ФФ стекло чтобы использовать на кропе - нонсенс. А приналичии, на кропе, 30-ки макро... ну, в общем странное стекло, для странной аудитории. ИМХО.
  16. В чем нонсенс? Типо "это же грех"? :D Ну я понимаю еще когда это экономически необоснованно. Но конкретно сабж относительно недорог.
  17. #57 7 авг 2015 в 14:20 | Sony SEL-28F20 - 28mm f2,0 (E-Mount) | Страница 3
    При наличии 30-ки макро, нет, не грех. Просто "тупость, глупость и нелепость".  :)  Но креативным гикам всё можно, не расстраивайтесь.
    PS: Нонсенс (англ. nonsense от лат. non — нет и sensus — смысл) — высказывание (реже — действие), лишённое смысла или само отсутствие смысла, бессмыслица. Разновидность алогизма или логической ошибки. Термин «нонсенс» очень близок по смыслу к термину абсурд (нелепостьнесообразность).
  18. Ну то что я видел на этом стекле(фф правда) и на 30ки макрике... То сравнение не в пользу макрика. Это личное мнение в любом случае=)
  19. К слову вот ваши же слова из темы про макрик
    > :D  Оставлю без комментариев.
    Обратите внимание на геометрию!!! Ни тебе подушки, ни бочки, красотища!!! Для интерьера, для пересъёмки документов-негативов. Чудо, как хорош. Ну, а для стрита и ночного пейзажа, действительно 35/1,8 будет предпочтительней.  :)
    Я думаю люди смотрящие на это стекло на кропе хотят иметь именно штатник, возможно аналог сгимы 30мм(кхе-кхе). А с конвертером еще и ширик.
  20. И хорошо, иначе придётся погрязнуть в рассуждениях, что 28мм и 35мм фокусного - две большие разницы.
    А зачем иметь аналог бюджетного объектива, за бОльшие деньги, при наличии в продаже оригинальной сигмы? Нонсенс! Т.е. глупость, нелепость. :) Нет. Использовать этот объектив на кропе - нонсенс, как не крути. :)
