Sony A7
Тема в разделе "Фотокамеры Sony NEX + E-mount фотокамеры", создана пользователем SergioDenisenko, 16 сен 2013.
  1. вот ты смеёшься, а я уже твёрдо решил, что немедленно продам это барахло (про А7), как только выйдет фефе тушка в стиле NEX-5n: DSLR wannabe оказалась непрактичной, совершенно неудобной для использования камерой
  2. #482 5 дек 2013 в 10:29 | Sony A7 | Страница 25
    [​IMG][​IMG] Не могу сказать, что офигенно удачные примеры. Я жду выходных, может доведется поснимать.. (ИСО 400, диафрагма f/2)
  3. 2 пользователям это понравилось.
  4. #484 5 дек 2013 в 15:53 | Sony A7 | Страница 25
    http://kurtmunger.com/sony_nex_carl_zeiss_24mmid316.html
    Conclusion.
    The Sony CZ NEX 24mm F/1.8 lens produces outstanding results throughout the entire frame, which is not typical for a wide angle lens; in fact, it shows the best results of any wide angle lens I've tested yet, and that includes full frame lenses like the CZ 24/2 and 35/1.4 G! Most wide angle lenses are mushy in the corners unless stopped down hard, but the NEX CZ 24/1.8 is actually quite sharp at F/1.8 in the corners! This lens is optically at its best between F/2.8-4, stopping down additionally is not necessary for sharper shots. A tid-bit that will make some people mad: I'm glad I don't have the Sony 35/1.4 G lens anymore, if I would've compared the Sony 35mm F/1.4 G using the A900, and the NEX CZ 24mm F/1.8 using the NEX-7 at apertures of F/1.8-4, the 35mm F/1.4 G would literally look like it was focused improperly, there would be that much difference at those apertures! Both cover the same area and have the same megapixels, so it's a fair comparison.
    Sharpness
    http://www.photographyblog.com/reviews/sony_carl_zeiss_sonnar_t_e_24mm_f_1_8_za_review/sharpness_1/
    http://slrgear.com/reviews/showproduct.php/product/1452
    Sharpness
    The Sony 24mm ƒ/1.8 is very sharp indeed, even when used wide open at ƒ/1.8. It's not tack-sharp corner-to-corner at that aperture, but it offers a large area of central sharpness with only light corner softness. Stopping down doesn't provide much improvement until you hit ƒ/2.8, and corner sharpness improves dramatically; maximal sharpness is achieved at ƒ/4, where it's not quite tack-sharp, but for most purposes, it's close enough. Sharpness actually drops off slightly at ƒ/5.6 and smaller, but there's no noticeable impact until ƒ/11. The lens can stop down as small as ƒ/22, where overall image sharpness is somewhat degraded.
    Conclusion
    Considering the price, you would hope that the Sony 24mm ƒ/1.8 Sonnar T* ZA didn't disappoint - and happily, it doesn't. Sharpness is excellent even wide open, and other factors such as chromatic aberration, distortion and corner shading are well-controlled. The 24mm ƒ/1.8 proves to be an able companion to the NEX camera.
  5. #486 5 дек 2013 в 16:15 | Sony A7 | Страница 25
  6. Не забудь выводами поделиться. Я слежу за темой, но брать буду не раньше, чем после анонса подводного бокса для этих моделей. Скорее всего это уже после анонса следующих моделей камер. :)
  7. Arax MC 35mm F2.8 Tilt+Shift
    Это родная? Читаем экзиф
  8. #489 5 дек 2013 в 16:35 | Sony A7 | Страница 25
    Юлия не читайте экзиф с яндекс-фотки. у меня тоже на некоторых выдает всякий ужас
    еще раз
    http://img-fotki.yandex.ru/get/9172/48740303.3/0_e3e56_88516ed_orig
    экзиф
    Camera Maker: SONY
    Camera Model: ILCE-7
    Lens: FE 35mm F2.8 ZA
    Image Date: 2013-01-08 00:17:27 (no TZ)
    Focal Length: 35.0mm (35mm equivalent: 35mm)
    Aperture: f/4.0
    Exposure Time: 0.017 s (1/60)
    ISO equiv: 800
    Exposure Bias: none
    Metering Mode: Matrix
    Exposure: program (Auto)
    White Balance: Auto
    Flash Fired: No (enforced)
    Orientation: Normal
    Color Space: sRGB
    GPS Coordinate: undefined, undefined
    Comment:
    http://img-fotki.yandex.ru/get/9063/48740303.3/0_e3e43_85018370_orig
    экзиф
    Camera Maker: SONY
    Image Date: 2013-01-08 00:17:51 (no TZ)
    Aperture: f/2.8
    ISO equiv: 400
    Exposure Bias: none
    Exposure: aperture priority (semi-auto)
    White Balance: Auto
    Orientation: Normal
    Color Space: sRGB
    Comment:
    для firefox
    https://addons.mozilla.org/en-US/firefox/addon/fxif/
    этот постоянно обновляется с выходом новых камер.
    или Exif Tool
    http://freeweb.siol.net/hrastni3/foto/exif/exiftoolgui.htm
    скачиваете ставите и начинаете смотреть экзиф, а не проверять по скрипту c ошибками из яндекс-фоток.
  9. Ок! Спасибо. Хотя с моими стеклами меня экзиф не подводил на яндексе.
  10. #491 5 дек 2013 в 16:57 | Sony A7 | Страница 25
    вот например
    http://fotki.yandex.ru/users/canonist1/view/723773/
    SEL 35/1.8 вдруг стал на яндексе вот этим: Объектив: T-Mount or Other Lens or no lens
    а надо так
    Camera Maker: SONY
    Camera Model: NEX-5N
    Lens: E 35mm F1.8 OSS
    Image Date: 2013-08-10 19:24:30 (no TZ)
    Focal Length: 35.0mm (35mm equivalent: 52mm)
    Aperture: f/1.8
    Exposure Time: 0.0020 s (1/500)
    ISO equiv: 100
    Exposure Bias: +1.30 EV
    Metering Mode: Center Weight
    White Balance: Manual
    Orientation: Normal
    Color Space: sRGB
    Comment:
  11. Подскажите, если кто проверял, работает ли LA-EA-4 на камерах Nex?
  12. Работает и поддерживает пикинг
  13. #495 5 дек 2013 в 17:51 | Sony A7 | Страница 25
    ничего другого вы и не могли написать.
    Я вот понимаю что проявляли родным конвертером который все портит. Но даже с учетом этого объем есть. Воздуха там и не должно быть ибо снимали у косяка, в офисе с жутким светом
    Вообще пора завязывать вам выливать негатив. Пусть каждый сам решает.
  14. На кропе работает ? Юлия Вы на семерке пробовали , поддерживает все функции ? Сегодня только эта мысль посещала , спросить у Вас .
  15. July, Спасибо, в таком случае думаю стоит приобрести LA-EA-4 для своего Некса, с перспективой использования на Альфе.
  16. Да, специально сейчас опробовала на некс-7 в режиме дмф. Все работает
  17. Родной конвертор плохо написанный и малофункциональный софт, но портить он ничего не портит.
  18. 4 пользователям это понравилось.
