Прошивки объективов Больше для Маньяка, но если кому-то хочется понапрягать аналитические извилины: Первый считываемый байт - FF, я его опустил. Minolta AF 70-210/4 - оказался самым капризным в электрическом плане, возможно там не все правильно считалось. Minolta AF 35-70/3.5-4.5 at 50/4: 0000000000: 81 26 50 03 1E 21 10 38 │ 2C 00 FF 3B FC 00 04 69 0000000010: 00 A4 00 FA 34 C8 03 23 │ 6A 25 00 00 B8 00 F3 B2 0000000020: 02 05 0C 00 00 00 00 00 │ 00 00 02 00 05 00 00 00 0000000030: 00 00 00 00 00 00 00 00 │ 00 00 00 00 00 00 00 00 Minolta AF 35-70/3.5-4.5 at 70/4.5: 0000000000: 81 26 50 06 1E 21 10 40 │ 2C 00 FF 2F 0A 00 04 64 0000000010: 00 A4 00 FD 34 C8 F5 25 │ 6A 25 00 00 B8 00 F3 B2 0000000020: 02 F9 FE 00 00 00 00 00 │ 00 00 02 00 05 00 00 00 0000000030: 00 00 00 00 00 00 00 00 │ 00 00 00 00 00 00 00 00 Sigma AF 105/2.8 Macro EX: 0000000000: 80 21 60 00 19 10 10 49 │ 23 00 FB 28 0E 00 00 39 0000000010: 00 B9 00 00 00 00 00 00 │ 00 00 00 00 00 00 D3 64 Sigma AF 28-70/2.8 EX DF at 70/2.8: 0000000000: 80 21 58 00 19 10 10 40 │ 23 00 FB 33 1C 00 00 4D 0000000010: 00 9F 00 00 00 00 00 00 │ 00 00 00 00 00 00 A7 63 Sigma AF 28-70/2.8 EX DF at 60/2.8 (?): 0000000000: 80 21 58 00 19 10 10 3C │ 23 00 FB 39 18 00 00 4A 0000000010: 00 9F 00 00 00 00 00 00 │ 00 00 00 00 00 00 A7 63 Sigma AF 28-70/2.8 EX DF at 50/2.8: 0000000000: 80 21 58 00 19 10 10 3A │ 23 00 FB 41 14 00 00 48 0000000010: 00 9F 00 00 00 00 00 00 │ 00 00 00 00 00 00 A7 63 Sigma AF 28-70/2.8 EX DF at 35/2.8: 0000000000: 80 21 58 00 19 10 10 30 │ 23 00 FB 52 13 00 00 3D 0000000010: 00 9F 00 00 00 00 00 00 │ 00 00 00 00 00 00 A7 63 Sigma AF 28-70/2.8 EX DF at 28/2.8: 0000000000: 80 21 58 00 19 10 10 2B │ 23 00 FB 5A 14 00 00 37 0000000010: 00 9F 00 00 00 00 00 00 │ 00 00 00 00 00 00 A7 63 Minolta AF 70-210/4 at 70/4 (75/4?): 0000000000: 80 29 58 00 21 00 20 42 │ 2B 00 FB 51 F6 00 00 82 0000000010: 00 CE 00 00 00 00 00 00 │ 00 00 00 00 00 00 CF 63 Minolta AF 70-210/4 at 100/4 (105/4?): 0000000000: 80 29 58 00 21 00 20 49 │ 2B 00 FB 42 FD 00 00 81 0000000010: 00 CE 00 00 00 00 00 00 │ 00 00 00 00 00 00 CF 63 Minolta AF 70-210/4 a bit more than 100/4 (120/4?): 0000000000: 81 29 58 00 21 00 20 4B │ 2B 00 FB 3F FE 00 00 82 0000000010: 00 CE 00 00 00 00 00 00 │ 00 00 00 00 00 00 CF 63 Minolta AF 70-210/4 near 135/4: 0000000000: 80 29 58 00 21 00 20 4F │ 2B 00 FB 36 00 00 00 84 0000000010: 00 CE 00 00 00 00 00 00 │ 00 00 00 00 00 00 CF 63 Minolta AF 70-210/4 at 150/4: 0000000000: 80 29 58 00 21 00 20 53 │ 2B 00 FB 2F F9 00 00 87 0000000010: 00 CE 00 00 00 00 00 00 │ 00 00 00 00 00 00 CF 63 Minolta AF 70-210/4 at 210/4: 0000000000: 80 29 58 80 21 00 20 59 │ 2B 00 FB 23 E5 00 00 91 0000000010: 00 CE 00 00 00 00 00 00 │ 00 00 00 00 00 00 CF 63 Minolta AF 50/1.7: 0000000000: 80 15 50 00 0D 00 20 39 │ 19 00 FB 40 00 00 00 5D 0000000010: E9 A9 00 00 00 00 00 00 │ 00 00 00 00 00 00 9D 63 На всякий случай, еще раз спрошу - есть у кого SSM объективы? Очень нужно. При считывании они не портятся. P.S. Спасибо gor-у за изготовленную им контактную площадку.
Спасибо. Платку пока не выслал, не спаял еще.До работы не добраться. Думаю что а начале следующей недели получится доехать. Отпукск, да и квартиру наконец-то достроили.Теперь ремонт делаю. Немного замотался. А кондер пускай лучше будет.Да и по месту не мешает, и паять тоже не сложно.
Minolta-Upiter 37PAF 135/3.5 А вот и мой вариант одуванчика Создавался из сабжевого юпитера и Минолта пуверзум 35-80 (кит от пленочной серии Xi)... Разобрал зум снял задник и обработал напильником , потом болтами прикрутил вместо юпитеровского задника... Работать с объективами серии Xi это еще то удовольствие, его еще надо както разобрать , вот где наворотов то, у него там целая раздаточная коробка, которая отвечает за изменение фокуса и зума за счет одного моторчика в камере . Отдельного упоминания стоит электронника данного сабжа, так там целый микрокомпутер на всякого рода шлейфиках, и этих шлейфиков мильен( я тут разобрал ради любопытства Минолта АФ35-105, так там одна микросхемка и шлейфик на указатель зума), пришлось основную массу этих шлейфиков ножницами покоцать, и даже после такой экзекуции, остался довольно толстый пучек. Так что бы спрятать данный пучек торчащий из уже готового юпитераодувана, отрезал часть корпуса зума и присобачил на новый задник, благо эта часть объектива и раньше крепилась к заднику.... Вот такой вот красовец получился...:yum:
Моторчик жужжит точно так же как и с обычной прошивкой и честно говоря очень напрягает, поэтому придется все равно переводить на ручную фокусировку с подтверждением. А вообще электронника будет выкидываться из него , не нравится она мне, фокусное 80 (а надо 135), моторчик жжужит.... Буду ждать, что ктонить всетаки сможет найти прошивку от ссм объектива...
Целиком задник от объектива присабачить - это круто, даже резиновое кольцо надел, да... Это сколько ж времени угрохать надо было? А вааще проблемы не только с моторчиком, экспозиция задолбала. При дневном освещении проблем не возникает, экспозицию на -1,5-2(у меня) и порядок. А сегодня пытался ребенка друзей поснимать в квартире - шиш. Камера как будто взбесилась, от кадра к кадру экспозицию подстраивать приходилось, и это при созданом нормальном освещении. Раньше такого не было, завтра попытаюсь разобраться в чем проблема, может с пьяну не те параметры на камере выставил, хотя вряд ли, достаточно много им уже снимал.
Конструкция выходного дня, сначало разобрал минолтовский кит на предмет замены группы линз на отечественную (во куда махнул) ну или хотябы посмотреть что там внутри.... Срузу же случайно порвал шлейфик идущий на переключатель зума-фокуса.... Куда теперь такой объектив нужен, ну вот пришлось хотябы задник на юпитер снять... По ошибке экспозиции, от куда бы ей не взяться, если прошивка объектива по умолчанию допустим выставляет д4,5 а у вас на объективе замер делается на Д2 или Д2.8, соответственно камера расчитывает выдержку неправильно... П.С. Поставить сов. группу линз в импортный объектив возможно, но в лучшем случае получится макрообъектив без смены диафрагмы....
Не..., не так. Прошивка чипа, конечно, предусматривает другую экспозицию, но при введении коррекции все должно быть нормально. Я ведь ставлю на камере ту же диафрагму, что и на объективе. Раньше так и было. Но, я кажется понял в чем у меня проблема. На моем одуване сильно окислилась контактная группа (она не золоченая), ща попробую почистить. Так и есть, зачистил контакты, при комнатном освещении экспозиция без коррекции, при естественном -1,5. Порядок.
Важный для меня вопрос возник, минимальные дырки мы примерно вычислили где в прошивке прописаны, теперь очень важно вычислить максимальные дырки.... Зачем это нужно? А нужно для перевода м42 объективов с одуваном еще и с сохранениеем рабочей прыгалки, механически это сделать возможно, вот только ход штока диафрагмы на заднике минолты примерно 12 мм, а у меня на заднике м42 Г77 (и Г44) получается примерно 7 мм (это есно если я переделываю задник)... Соответственно нужен пересчет хода диафрагм, на 7 мм... В принципе если ход штока у минолты при 12 мм перекрывает диапазон диафрагм 3.5-32, а ход штока г77 - 1.8 -16 то получится гдето близко, но все равно не точно... Соответственно надо еще больше расширить диапазон дифрагм у минолтовской прошивки...
Гемморойно все это. Время, которой Вы потратите на переделку привода прыгалки, ИМХО, лучше потратить на что-нить более полезное.
Для объективов типа Г44 и Г77 с не отключаемой прыгалкой, проблема решается легко, надо только немного послесарить, ну самую малость и поработать эпоксидкой. Объектив будет работать с прыгалкой как работал на зените, т.е корректно... С АФ камерами работает с погрешностью(нарушается дискретность переключения, на камере ставится дырка 2.8, а реально прыгалка закрывается до 5.6), которую можно устранить перепрошивкой одувана (я надеюсь , что в прошивке всетаки есть байты отвеающие за макс. диафрагму)... Я надеюсь что ни кто не будет отрицать , что фокусироваться на диафрагме 1.8 или 2 гораздо удобнее, быстрее и точнее чем на 4.
Автоматизация работы диафрагмы - это, конечно, интересно (хотя и результат будет слишком трудно достижим). В качестве базовой прошивки можно взять прошивку от Sigma 105/2.8 - у него минимальная диафрагма - f/45.
Задник для г77 с прыгающей диафрагмой уже изготовлен... (пришлось пожертвовать задником ранее изготовленным под Ю37А), с помощью пинцета все работает, на камере проверить пока не получается, т.к. во первых полетел мой единственный одуван (доигрался, порвался шлейфик:'( ), во вторых задник пока не закреплен(ну это дело времени, будет свободный часок, сделаю, проблем с этим нет, необходимо просверлить в заднике 4 отверстия, и потом подгонять его по бесконечности на объективе).... Но все равно, разберусь с электронникой, все должно работать не хуже родных объективов....
Это конечно не та тема, но могу выслать переделку аналогового матового стекла (с растром и с клинами), для D5D. Я вот себе сделал - очень легко фокусируется с аналоговыми стеклами и на м42 и для Пентакона 6. Даже на диафрагме 1,4 (хотя на моей Минолте D5D иногда ловит Back fokus). Тут лежит инструкция и чертеж по польски. http://alfaklub.pl/forum/showthread.php?t=5155&highlight=przerabianie
