Две таинственные DSLR-камеры Sony
Тема в разделе "SONY с байонетом А", создана пользователем KR@N, 3 мар 2007.
  1. На счёт 1.1 вообще-то пока не ясно, будет ли он вообще, возможно эти две камеры расчитаны и на 1.5, с разницей в качестве матриц и общей насыщенности функционала. По крайней мере даже старшая модель на вид, не тянет, ни на Марк ни на D2 от никона.
  2. Возможно, но старые то линзы расчитаны на 1.0 т.е. на плёнку, и если этот 1.0 будет ещё и вибрировать, то будет виньтирование...
  3. а кеноновская пИтЕрочка тянет на Марк?
  4. У кенона FF уже давно, а тут скорее упрощенная D2x должна появиться, но как знать, осенью посмотрим.
  5. RulerM
    13 фев 2006
    Saratov, Russia
    Более подробная инфа с конференции:
    http://www.hypersensory.com/sony_alpha_dslrs_announced
    Finally! As I have predicted earlier, Sony is releasing two new Alpha DSLRs! Both will be featuring larger than any of current Sony/Konica-Minolta sensors, faster processors, larger buffers, more detailed and possibly larger screens, Super-Steady-Shot (Sony’s version of Anti-Shake), and some other minor updates. As always, they will accept compact flash cards and memory-stick designed by Sony.
    At the same time they are introducing several new Alpha mount (Minolta A-mount) lenses – 24-70mm f2.8 (hopefully G class and not a Sony version of the Minolta 28-75mm f2.8), 18-250mm hyper-zoom, and a couple of other consumer grade lenses.
    The flagship system (pictured on your left) will be similar to Minolta Maxxum 9 (but will not have a pop-up flash) and will be aimed at pro-photographer working in the studio or with a lot of extra equipment. It also seems that Sony may have a new flash system in the development, which is likely to use methods other than pre-flash for triggering the main flash system ( if it is in plans, the earliest it could come out is at the end of 2008). But for now, the pro-level camera will be limited to using a flash-sync cable for off-camera flash operation. It will feature one of the brightest and biggest viewfinders, will come with PC-sync port and software to download the images straight to computer. At the same time Sony will be releasing vertical grips for both of the new cameras.
    Now a bit of not so good news - Sony has decided to not follow the brilliant layout of the Minolta Maxxum cameras, but instead to design their own bodies. As a result, they will not have as many physical manual controls (buttons and dials) but will rely on the back and top LCD screens for many settings and adjustments.
    Some more detail emerging:
    "Amateur model": No spring loaded flash (has to be raised manually like on 5D/7D), size similar to Minolta 7D; not confirmed, but appears to have electronic wireless remote capability; has spot/area/center weighted metering selector; focus area selector is not present on the multifunction joystick/pad; takes both CF and memory stick cards; other buttons present (DOF, AEL, AF/MF, Super-Steady-Shot,Function, C, 2 multifunction dials, 1 multifunction thumb dial, viewfinder diopter adjustment dial, S/A/C/MF focus selector, IR sensor, Mode dial, ISO button, WB button; LCD buttons - menu, LCD mode, delete, play; and some others.
    "Flaghship model" will have almost identical controls except for a couple of extra buttons (Drive - goes through single, braket, continuous), no picture modes except for standard M/S/A/P (free space on the dial is likely to be replaced by programmable "memory" modes).
    Judging by the size difference of the viewfinder, but otherwise very similar appearance it seems that Sony plans to make main differentiation of the models not in their controls or general functionality, but by improved performance and image quality. And the best way to do this is with a larger and more potent sensor. From the information we have been able to gather so far, it does appear that the pro body will feature a full frame sensor. However, the body shown at PMA is still only a mock-up and not even a pre-production model. It is likely that while the exterior and controls have been mostly finalized, the electronics and specs of the pro model are quite far from set in stone.
  6. Про то что старшая модель будет ФФ, уже сомнения вряд ли есть. Все косвенные признаки говорят об этом.
    А это что такое?
  7. У меня появилась в жизни мечта - купить когда-нибудь полнокадровую Sony. Родные говорят, что я сошел с ума, о детях надо думать и все такое, но ничего не поделаешь. Мне есть ради чего жить и работать. Лет через 5-7 обязательно куплю. Посмотрю в видоискатель. И умру от счастья. У меня есть полнокадровая цифровая зеркалка.
  8. можно сейчас купить пленочную семерку или девятку, а не ждать счастливой смерти целых 5-7 лет :cool:
  9. во,во я так и сделал! чтоб "посмотреть в большой видоискатель" достаточно пленочной семерки. а снимать необязательно если лень с проявкой возиться :)
  10. Вы не один такой на этом свете ;)
    Мне, правда, морально полегче, т.к. один..
  11. Пленочная зеркалка у меня есть - Зенит. Старенькая, но работает. Я давно не снимаю на пленку. Только в детстве/юности на ч/б, когда отец учил, помогал. Верно было подмечено - сегодня лень возиться с проявкой, да и я привык не жалеть кадры.
    Недавно знакомый давал посмотреть в видоискатель своей пленочной Nikon, я словно увидел новый мир. Такой большой. Глубина резкости фантастически подчеркивается, хотя объектив стоял какой-то заудярный, типа ~28-100 (не помню, зум какой-то).
    Но мечта все равно остается. Одеть свой 24/2.8, и получить именно 24, а не обрезок а-ля 35мм. Широкий угол, простор.
    Одеть полтинник и получить именно полтинник, а не "недопортретник" :)
    Мне кажется, это будет прекрасно. Дай Бог, чтобы через ~5 лет подобные камеры стоили <2000$. Такую сумму я осилю ради мечты. :)
  12. а кто мешает сейчас нацепить 35/1.4 на Вашу камеру и получить "именно полтинник"? ;)
  13. Хорошо вам иметь только такую мечту. Видимо уже есть большая хорошая квартира, новый автомобиль, загородный коттедж...
  14. igorkon
    От этого видоскатель не станет больше. Да и дорогой он, 35/1.4. Полтинник-то я за 2500р покупал :)
    Wingsword,
    Нет :) У меня есть средняя квартира, нет автомобиля и обычная советская дача 6x4, где больше бывают воры, чем я :)
    Кстати, я никогда не мечтал о трациционных материальных ценностях. Наверно потому, что вырос во вполне благополучной семье, все было. И работу очень люблю, поэтому не думаю о деньгах, о всяких отпусках и прочих прибамбасах.
    Фотография - это такое удовольствие. Вот даже вчера. Съездил к родителям. Поздравил мать, после обеда с часок поиграл с кошкой, поснимал ее. Это же такое удовольствие. И еще днем раньше пошел просто гулять пешком по пригороду. Гулял, снимал Волгу, парк, аллеи. Солнце светит, морозно, просто сказка.
    Жена смеется, дразнит: не "зеркалка", а сына в руках держишь, не снимаешь, а воспитываешь. Мысли у тебя глупые.
    Ну и пусть глупые :)
  15. #75 9 мар 2007 в 15:57 | Две таинственные DSLR-камеры Sony | Страница 4
    Давайте сравним обе камеры "со спины"!
    Видно, что отличия тушек минимальны.
    Меня опять терзают смутные сомнения, что у обеих камер совершенно идентичные рукоятки. :cool:
    На Сонивском форуме dpreview.com обсуждается предположение о том, что Сони спецом заранее закинула приблизительный макет А1, что бы собрать критику и инфу от потенциальных потребителей о том, какую тушку они бы хотели в итоге получить.
  16. #77 9 мар 2007 в 16:14 | Две таинственные DSLR-камеры Sony | Страница 4
    да было бы хорошо что бы одна рукоядь ко всем тушкам подходила...
    Эх когда нить сделают что тока процессор и матрицу меняешь и новая супер тушка с ещё большими мегапикселями :)
  17. она никогда и не планировалась
    сони еще изначально сказала что А100 будет младшей моделью
  18. #79 9 мар 2007 в 16:22 | Две таинственные DSLR-камеры Sony | Страница 4
    У ребят на http://forums.dpreview.com попёрли фантази на тему спецификаций новых тушек:
    Alpha A10 (semipro)
    => 12 MPixels CCD, APS-C size
    => 5 fps burst
    => VF: 0,92x magnification // 0,95x coverage
    => ISO 100-3200
    => 3" screen
    Alpha A1 (pro)
    => 23 MPixels, 1,05x crop or close to
    => 5 fps burst
    => ISO 100-6400
    => 3,5" screen
    => weathersealed body
  19. Экраны если и будут, то 2.5 и 3.0, тушки то маленькие...
    А сечас и вовсе одинаковые стоят, видимо 2.5
