Две таинственные DSLR-камеры Sony
Тема в разделе "SONY с байонетом А", создана пользователем KR@N, 3 мар 2007.
  1. Одни догадки можно строить, черт его знает!
    Вроде 8 новых линз будет аносировано, судя по тексту...
  2. #22 8 мар 2007 в 23:48 | Две таинственные DSLR-камеры Sony | Страница 2
    http://www.dpreview.com/articles/pma2007/Sony/
    Big news on the Sony stand is the announcement of two additions to the Alpha digital SLR range, though details are sketchy, to say the least. There are a couple of mock-up models on show, behind glass, but we're told that these are far from being close to final production designs. The two SLRs announced today are a high end amateur model that will sit above the A100 in the range (it is not a replacement for the current camera) and a professional body. Our contact at Sony couldn't give us any more detail on spec, timing or pricing, though they did confirm that only the first (the high end amateur model) will arrive this year (we're expecting to hear more in the fall). Both cameras will have new sensors (with Super Steady Shot stabilization) and enhanced Bionz processors.
    Sony also showed a very rough lens roadmap with 8 new concept lenses (zoom and fixed focal length), with at least five due to be announced before the end of 2007. The only detailed spec we could get out of Sony was on the three lenses they expect to launch firstl 24-70mm F2.8, 70-300mm F4.5-5.6 and a DT 18-250mm F3.5-6.3. We were told that all these lenses have been designed and developed by Sony (in other words they are not based on Konica Minolta designs).
    Большие новости относительно стенда Sony - объявлены два дополнения к модельному ряду DSLR Alpha, хотя детали отрывочны..... Имеется пара моделей макетов на выставке, за стеклом, но нам объяснили, что они далеки от финальных продуктов. Два SLRS объявленные сегодня - это верхний уровень любительскаой модели, которая будет позиционироваться выше A100 (это - не замена для текущей камеры) и профессионального боди. Наш источник в Sony не мог предоставить нам больее детальной по цпецификации и характеристикам информации, хотя они подтверждали, что только первая камера(продвинутая любительская модель) поступит в продажу в этом году ближе к осени. Обе камеры будут иметь новые матрицы (с Super Steady Shot стабилизацией) и улучшенными Bionz процессорами.
    Sony также показала очень приблизительный линзовый roadmap с 8 новыми линзами-концептами зумов и фиксов, по крайней мере пять из них должный быть объявленны перед концом 2007 года. Единственную дополнительную инфу, которую мы смогли получит от Сони - это то, что первые три линзы, которых начнётся выпуск: 24-70mm F2.8, 70-300mm F4.5-5.6 и DT 18-250mm F3.5-6.3. Нам сказали, что все эти линзы были разработаны и доведены Sony (другими словами они не основаны на KonicaMinolta проектах).
  3. Кстати, посмотри подобный разворот на Sony A1. Там точно Planar 1.4/85, с другой стороны объектива надпись Sony! Значит 1.4/35 будет Zeiss :cool:
  4. Хуже того
    Это ИМХО не макет а очередной туфтовый монтаж. Ны втором сномке сверху когда лейбл альфа в шопе лепили поленились углы согласовать. Наверное фрее трансформ не знают:)
  5. 1 интересная
    2 скучная, такая уже есть
    3 тамрон наверное, тоже скучно
  6. #26 8 мар 2007 в 23:56 | Две таинственные DSLR-камеры Sony | Страница 2
    с учетом колличества фотографий и источников - определенно нет.
    DT 18-250mm F3. 5-6.3 - это тамрон с вероютностью 90%
    интересно, теперь все новинки это перелицованные тамроны или новые цейсы будут? если из бютжетных только тамрон останется - как-то грустно...
  7. RulerM
    13 фев 2006
    Saratov, Russia
    #27 9 мар 2007 в 00:10 | Две таинственные DSLR-камеры Sony | Страница 2
  8. RulerM
    13 фев 2006
    Saratov, Russia
    ИМХО разговоры от Сони, что все линзы Сони - такая же туфта, как и до этого максимальное открещивание от Минолты. 70-300 - на 90% бывший 100-300АРО, растянутый до 70. 28-250 - на 90% Тамрон.
  9. Крайний правый черный, STF что ли...
  10. А я немного расстроился,глядя на эти снимки.Вовсе на Семерку и не похоже,опять кнопки(назад в будущее?) и нет рычагов(может сзади?)А с кнопками это как у Никона и ЖК монитор тоже...Одно улучшение заметил-переключение режимов автофокуса удобнее стало.
    Хотя люди и Никонами с Кенонами снимают,и как то не жалуются.У Минолты был экспонометр не самый лучший,да и вспышке помогать приходилось.Если исправили,то можно(если редко)и кнопками обойтись.
    Ну да ладно ,поживем-увидим...
  11. Есть некоторое разочарование... Я постоянно дёргаю рычажок компенсации пыха и режимы драйва... а вот компенсация экспоциции у меня всегда на колесе назначена (имхо удебонее, чем постоянно крутить верхнее левое большое колесо)... В любом случае проблему можно решить дополнительными кнопками. :cool:
  12. имхо колесо это вообще неудобное на семерке.
    удобнее когда все важные функции под правой рукой . в этом плане на альфе мне больше нравится - там две кнопки коррекции + и -. видимо они решили это оставить
  13. Это для той группы, кто всю жизнь китом снимает. Так сказать, один объектив для всего и навсегда.
    Насчет ручек. На снимке с парой камер видно, что ручка A1 вблизи кнопки сбоку сделана по-другому.
  14. Его эзотерический смысл в том, что видны настройки на невключенной камере. И что настройки можно поставить до съемки под опр вспышку и объектив.
  15. Одно радует-Альфу нынешную брать не прийдется,лучше свою 7Д починить.И монстр с пентапризмой огромной,хоть и архаично,но впечатляюще.
  16. Дык и на Никоне видно,ЖК монитор не выключается...
  17. #40 9 мар 2007 в 01:03 | Две таинственные DSLR-камеры Sony | Страница 2
    Отличия минимальны по-любому.
    ИМХО вообще делать съёмную рукоятку для А1 глупо. Ведь понятно, что без неё камера "кастрированная", а тут ещё профитушка (как бы). Сделали бы формфактор боди типа EOS 1D. Или они хотят так удешевить тушку, или дополнительно заработать на продажах рукояток по мегаценнику???!!!
    ЗЫ
    Ищи их потом, лови их потом....эти рукоятки!!! мля...
