Camera Raw 9.1.1 plug-in installer for CS6, CC, CC 2014, CC 2015 29/07/2015 Прямые ссылки на закачку: Win здесь Mac здесь Спойлер: Изменения: New Camera Support in Camera Raw 9.1.1 Canon PowerShot G3 X Casio EX-100F Casio EX-ZR3000 Leica Q (Typ 116) Olympus AIR-A01 Panasonic Lumix DMC-GX8 Panasonic Lumix DMC-FZ300 Panasonic Lumix DMC-FZ330 Pentax K-3 II* Phase One IQ3 50MP Phase One IQ3 60MP Phase One IQ3 80MP Ricoh GR II Sony A7R II (ILCE-7RM2) Sony DSC-RX10M2 Sony DSC-RX100M4 * Please note the following limitations specific to camera support for the Pentax K-3 II: Pixel shift Resolution (PSR) mode was added in this release. It is recommended to use a tripod and use a 2-second timer to minimize motion artifacts when in PSR mode. Images created with the In-camera HDR mode are not supported in ACR and Lightroom. Users who wish to shoot multi-capture HDR in raw mode should shoot separate files and merge to HDR using ACR/Lr’s Merge feature. Click here to learn more about merging files in Lightroom. New Lens Profiles in Camera Raw 9.1.1 Mount Name Canon Lensbaby Velvet 56mm f/1.6 Fujifilm Lensbaby Velvet 56mm f/1.6 Nikon Lensbaby Velvet 56mm f/1.6 Nikon SIGMA 24mm F1.4 DG HSM A015 Nikon SIGMA 150-600mm F5-6.3 DG OS HSM C015 Olympus Lensbaby Velvet 56mm f/1.6 Panasonic Lensbaby Velvet 56mm f/1.6 Pentax Lensbaby Velvet 56mm f/1.6 Samsung Lensbaby Velvet 56mm f/1.6 Sigma SIGMA dp0 Quattro Sigma SIGMA 150-600mm F5-6.3 DG OS HSM C015 Sony A Lensbaby Velvet 56mm f/1.6 Sony E ZY Optics Mitakon 35mm f/0.95 Sony FE Lensbaby Velvet 56mm f/1.6 Sony FE Zeiss Batis 25mm f/2 Sony FE Zeiss Batis 85mm f/1.8 Fixed Bugs: Fixed an issue with occasional visual artifacts in Photoshop after running Camera Raw in GPU mode. Fixed an issue where automatic lens profile matching did not work for the Schneider LS 150mm f/3.5 lens. Fixed an issue with distortion correction for some images captured with the Canon EF 8-15mm f4L Fisheye USM lens. Improved quality of lens profiles for Nikon COOLPIX P330 and Nikon COOLPIX P340 cameras. Improved speed of loading Fujifilm X-Trans raw images. Fixed an issue where the slider knob would “jump back to its starting position” when the cursor moves beyond the slider interface.
доброго времени суток . уважаемые форумчане . не могу установить на винду 8.1 фотошоп цс6 , постоянно выскакивает ошибка . в чем может быть проблема ?
Это и не удивительно, что не можете: здесь, на странице адоб указаны системные требования Photoshop CS6: "- Microsoft® Windows® XP с пакетом обновления 3 (SP3) или Windows 7 с пакетом обновления 1 (SP1)." И далее: "- Приложения Adobe® Creative Suite® 5.5 и CS6 также поддерживают Windows 8 и Windows 8.1. Подробнее о поддержке Windows 8 см. в разделе часто задаваемых вопросов по CS6*" Но я бы назвал ситуацию как-бы поддерживают. Не в полном объёме, на ваш страх и риск. Посмотрите их страницу здесь. Там они прямо пишут: как и с любой новой версией операционной системы, неожиданные вопросы, которые не были обнаружены во время тестирования, могут возникнуть. И советуют: если у вас возникли вопросы, то сообщите о них с помощью формы отправки багов: здесь Дело ваше, но зачем вам такая старая версия Adobe Photoshop?
Уважаемый nauticus в моем CS6 нет Бриджа. Возможно ли добавить его ? Версия CS6 Ekstended 13.1.2. x32
Так а что мешает вам поставить Adobe Bridge CS6? ps хотя я бы остановился на Adobe Bridge CC. Заодно и Adobe Photoshop CC 2015 поставил бы как минимум, если позволяет ваше железо. См. личку.
Полистал чуток, не встретил ссылки на закачку Photoshop CS6. Так задумано? Или не туда зашёл. Обычно на первой странице было.
с оффсайта все скачивают а вообще я откатился на 2014, потому как кнопку сохранить для вэб еще дальше засунули...
Так просто он уже для большинства пользователей неактуален. И ветка поэтому полуживая. А со ссылками на него проблем нет. Держите, прямая ссылка с адоба: Adobe CS6 Master Collection, в том числе Adobe Photoshop CS6. Или вот вам ссылка на сам фтпшник адоба. Для тех кто не в курсе: Adobe после обновления 13.1.2 отказалась от поддержки Windows XP: при запуске просит обновить систему. Так что последний фотошоп, работающий под Windows XP - Adobe Photoshop CS6 (13.0) Разработчики решили пойти на этот шаг, поскольку новое программное и аппаратное обеспечение позволяют значительно улучшить производительность графического редактора, а также добавить некоторые интересные функции. Ликвидация поддержки Windows XP позволило оптимизировать графический редактор, добавив такие функции, как 3D, Blur Gallery и Lighting Effect, недоступные для пользователей Windows XP.
Спасибо. Гляну обязательно.Дня четыре назад скачал CS6 ru, при кратком ознакомлении мало чем отличается от старого. А что сейчас актуально из подкручивающих программ?
Друзья прошу помощи. Суть проблемы такова: Картинка в фотошопе при ее увеличении немногим меньше чем размер рабочей области смотрится как то очень шершаво, при дальнейшем увеличении приобретает нормальный вид. При чем в штатном просмоторщике картинка смотрится нормально при том же увеличении((( ниже прилагаю скрин из фотошопа и со штатного вьювера. Может что в настройках самого фотошопа или драйверов системы? Тот же фотошоп на ноутбуке работает нормально
Стоит CS6 но без Bridg Возможно ли установить дополнительно Bridg и где его взять. Винда7 64-х разрядная.
Купить. Другие варианты на форуме не рассматриваются. Я в CS6 не работал вообще, но если исходить из того, что Adobe Bridge CS6 это составная часть Adobe Photoshop CS6, то вам нужно переинсталлировать программу, изменив при установке набор компонентов, зафлажковав при этом нужные компоненты, а именно Adobe Bridge CS6. Может быть видео вам поможет: [video=youtube;1T6ExmW-oUk]https://www.youtube.com/watch?v=1T6ExmW-oUk[/video]
Уважаемые фотошоперы ! Кисть перестала работать в режиме быстрой маски. Может какие настройки сбил ? Режим наложения нормальный. "Выделения" все работают в режиме маска, а кисть ни в какую . Что делать ?
Ввиду отсутствия файла на адобовском сайте перезалил ACR 9.1.1 под Win: Camera Raw 9.1.1 plug-in installer for CS6, CC, CC 2014, CC 2015 29/07/2015 Camera Raw 9.1.1 является самой последней версией, совместимой с Bridge CS6 и Photoshop CS6. For Bridge CS6 and Photoshop CS6, substitute with the Camera Raw 9.1.1 installer below. Скачать Win: ЯД MEGA
Скачать Camera Raw 9.1.1 plug-in installer (последнюю версию, совместимую с Bridge CS6 и Photoshop CS6) с сайта adobe: Windows CameraRaw_9.1.1 macOS CameraRaw_9.1.1
