http://helpx.adobe.com/x-productkb/multi/camera-raw-plug-in-installer.html Вышло обновление Camera Raw 8.6
Обновился ACR до 8.8.0.397 https://helpx.adobe.com/x-productkb/multi/camera-raw-plug-in-installer.html
Обновился ACR до 9.0.0.414 https://helpx.adobe.com/x-productkb/multi/camera-raw-plug-in-installer.html
Обновился Camera Raw до 9.1.0.441 New Features DehazeMany outdoor scenes have some amount of haze due to atmospheric conditions. Dehaze is a new feature for removing/adding haze and fog from pictures. The user can control how much haze to remove by adjusting a new slider in the Effects panel in the Dehaze section. This feature can also be used in the other direction to increase the amount of haze. Recommended Workflow – Adjust the white balance of the image before applying the Dehaze control. [*]Local White and Black Adjustment Sliders Available with all 3 local adjustment tools: Gradient Filter, Radial Filter and Local adjustment brush Useful for fine-tuning tonality near the brightest and darkest parts of the picture. For instance, they can be used to increase the contrast of highlights. Recommended Workflow – Make your global adjustments first and then use the local adjustments to fine tune. Use the clip warning indicator to help avoid clipping highlights and shadows. Fixed Bugs: [*]Reduced “color blur” artifacts when processing Fujifilm X-Trans raw images. In collaboration with Fujifilm, we are still investigating methods to improve fine detail rendering and overall edge definition. [*]The “Remove Chromatic Aberration” checkbox is now enabled by default for all Fujifilm cameras. [*]Fixed crash when reading some JPEG images. [*]Fixed bug where Camera Raw Filter would incorrectly show a soft-proofed image. [*]Improved quality of display color management on some wide-gamut displays when GPU acceleration is enabled. [*]HDR and Pano Merge: Cleared in-camera crop before merging rather than destructively applying it prior to merging. [*]Pano Merge: Fixed a Pano blending issue specific to Leica M9. [*]Fixed a bug with Panasonic LX100 – extended ISO 100 was too bright and Magenta Highlights have been fixed. [*]Fixed a bug with Nikon Coolpix P7800 NRW raw files that showed only Matrix as camera profile.
Обновился Camera Raw до 9.1.1.461 Camera Raw 9.1.1 is now available through the update mechanism in Photoshop CS6 and Photoshop CC. New Camera Support in Camera Raw 9.1.1 Canon PowerShot G3 X Casio EX-100F Casio EX-ZR3000 Leica Q (Typ 116) Olympus AIR-A01 Panasonic Lumix DMC-GX8 Panasonic Lumix DMC-FZ300 Panasonic Lumix DMC-FZ330 Pentax K-3 II* Phase One IQ3 50MP Phase One IQ3 60MP Phase One IQ3 80MP Ricoh GR II Sony A7R II (ILCE-7RM2) Sony DSC-RX10M2 Sony DSC-RX100M4 Fixed Bugs: Fixed an issue with occasional visual artifacts in Photoshop after running Camera Raw in GPU mode. Fixed an issue where automatic lens profile matching did not work for the Schneider LS 150mm f/3.5 lens. Fixed an issue with distortion correction for some images captured with the Canon EF 8-15mm f4L Fisheye USM lens. Improved quality of lens profiles for Nikon COOLPIX P330 and Nikon COOLPIX P340 cameras. Improved speed of loading Fujifilm X-Trans raw images. Fixed an issue where the slider knob would “jump back to its starting position” when the cursor moves beyond the slider interface.
Вышло обновление для Photoshop CC2014 (15.2.2) Affected software versions Adobe Photoshop CC 2014 (15.2.2) (2014.2.2) and earlier versions for Windows and Macintosh Solution Adobe recommends users update their software installation via the application's update mechanism by launching the application, navigating to the Help menu, and clicking "Updates". Patches for Adobe Photoshop CC 2014 (15.2.3) are also available at the following locations: Win (32-bit): http://www.adobe.com/support/downloads/detail.jsp?ftpID=5952 Win (64-bit): http://www.adobe.com/support/downloads/detail.jsp?ftpID=5951 Mac: http://www.adobe.com/support/downloads/detail.jsp?ftpID=5950 Note: These updates will not show in the Applications & Updates section of the Creative Cloud Packager. Please download the patches directly from the links above, and use the option to “Add Offline Media” as described in the workflow documented here.
Adobe Camera Raw 9.2 https://helpx.adobe.com/x-productkb/multi/camera-raw-plug-in-installer.html New Features in Camera Raw 9.2 Dehaze as a Local Adjustment - We added Dehaze as a global adjustment in the Camera Raw 9.1 release and are excited to see the widespread interest in the feature. We wanted to extend the functionality, and I’m happy to announce that you can now apply Dehaze as a Local Adjustment. This means that you can use Dehaze with the Radial Filter, Graduated Filter and Local Adjustment Brush. Birds Eye View - This is a fast way to navigate across the image, especially when zoomed in. It is similar to the existing feature in the Photoshop app itself. Here’s how to use it:
Adobe Camera Raw 9.3 .1.520 https://helpx.adobe.com/x-productkb/multi/camera-raw-plug-in-installer.html
Adobe Camera Raw 9.4 .0.548 http://swupdl.adobe.com/updates/oobe/aam20/win/PhotoshopCameraRaw8-8.0/9.4.51/setup.zip
Camera Raw 9.7 now available Camera Raw 9.7 installer Windows CameraRaw_9_7.zip Mac OS CameraRaw_9_7.pkg.zip
Photoshop CC 2015.5 Release 17.0 20.06.2016 Прямые ссылки на закачку: win64 win32 mac What’s New in Adobe CC 2015.5? Прошу всех учесть, что 2015.5 это не обновление, это другой релиз Adobe Photoshop CC (как CC 2014 и CC 2015). Он инсталлится отдельно и независимо, предыдущие версии не затрагивает. Соответственно, и плагинов, ранее установленных на предыдущие релизы Adobe Photoshop CC, у него тоже не будет. Их придётся переустанавливать.
Adobe Photoshop CC 2017.0.0 (2016.10.12.r.53) Новые функции Adobe Photoshop CC 2017: • Поиск в приложении. С помощью новой панели поиска можно быстро найти инструменты Photoshop, панели, меню, ресурсы Adobe Stock, справочные материалы и руководства прямо в мобильном приложении. • Улучшенная интеграция с Adobe XD. Теперь можно копировать элементы SVG в буфер обмена и вставлять ресурсы проектов Photoshop в Adobe XD. • Быстрое создание проектов. Чтобы быстро создать новый проект, используйте встроенные шаблоны или бесплатные шаблоны Adobe Stock, доступные в меню «Файл» > «Создать». • Стоковые шаблоны, 3D-объекты и поиск. В магазине Adobe Stock теперь доступны шаблоны для дизайна и 3D-объекты. Перетащите стоковые элементы из результатов поиска на панели «Библиотека» прямо на холст и приступайте к работе. Чтобы выполнить визуальный поиск похожих изображений, щелкните правой кнопкой мыши на стоковом изображении. • Улучшенная панель «Свойства». На панели «Свойства» теперь отображается не только информация о документе, но и информация об основных типах слоев, что упрощает точное редактирование. • Поддержка цветных шрифтов SVG. Все установленные на компьютере шрифты SVG теперь доступны в меню «Шрифт» в приложении Photoshop. Растровые и векторные шрифты SVG прекрасно подходят для гибкого дизайна, так как поддерживают различные цвета и градиенты. • Новые возможности Creative Cloud Libraries. Библиотеки в Photoshop теперь поддерживают шаблоны Adobe Stock. Также обновлена функция «Отправить ссылку». Теперь можно предоставлять доступ к публичным библиотекам в режиме «Только чтение». Отслеживаемые библиотеки отображаются на панели «Библиотека» и автоматически обновляются. Улучшения Creative Cloud Assets. Выполняйте архивацию и восстановление и просматривайте историю версий всех ваших ресурсов Creative Cloud, включая файлы в библиотеках Creative Cloud Libraries, ресурсы, созданные в приложениях CC для настольных компьютеров, и мобильные проекты. • Доступ к магазину Typekit Marketplace. Приобретайте шрифты от ведущих дизайнеров и используйте их в ваших проектах Photoshop. Typekit поддерживает синхронизацию шрифтов и веб-технологии, позволяющие получать доступ к шрифтам Marketplace из любых приложений и на любых устройствах. • Общие улучшения производительности. Приложение Photoshop теперь работает еще эффективнее благодаря улучшениям производительности, таким как инструмент «Пластика». • И многое другое. Прочие улучшения: функция «Пластика с учетом черт лица» с возможностью независимой корректировки глаз, улучшенный пользовательский интерфейс для функции «Подбор шрифта» и многое другое.
Сравнение прежних версий с возможностями Photoshop CC 2017 Новое в Photoshop CC 2017. Обзор новых функций Photoshop CC 2017
