Анонс а33 и а55 Обзор а55 на DPReview Анонс Sony a35 Обзор а35 на DPReview Ключевые характеристики: Полупрозрачное зеркало, 70/30 пропускание/отражение 16 (а55 а35)/ 14 MP (а33) сенсор 60 -1/4000 sec. X-sync 1/160 sec ISO 100-12800 (25 600 в Jpg) 15 точек АФ, 3 креста видео AVCHD: 1920 x 1080, 59.94i (29.97fps sensor output) Motion JPEG: 1440 x 1080, 29.97p/ 25p 640 x 480, 29.94 fps 10 (а55) 7 (а33/а35) FPS в "высокоскоростном" режиме 6FPS в обычном в/и 1.1*100% 1.4МП
По результатам теста от дпревтью: Conclusion - Pros Reliably good image quality at lower sensitivities High ISO JPEG output usable up to ISO 12800 for smaller prints Excellent LCD and good EVF, with efficient automatic switch. Versatile and capable (for its class) 15-point AF system Accurate metering and focus Very Good JPEG resolution Very good (almost 9EV) dynamic range Good quality HD video output Swivel-screen useful for overhead- and video shooting Good ergonomics all around, good build quality, nice handling Very compact design Excellent digital level gauge in EVF/LCD Useful Fn menu allows direct access to many important settings Very usable manual focus mode (including up to 15x image magnification) Lots of cool features - 10fps, Auto HDR, Multi-shot NR etc., (automatically selected in Auto+ mode) Auto+ mode makes the various continuous shooting modes (see above) available to novices Efficient image stabilization system Conclusion - Cons Limited control in 10fps and movie modes AF system not quite up to capturing fast action No live view in 10fps/6fps shooting makes panning almost impossible Slow (50 seconds) buffer clear time (RAW-mode) Little control over high ISO noise reduction ('auto' or 'weak') Visible loss of detail at anything over ISO 400 (noise reduction too strong) Menu system a little confusing (hard to orientate yourself sometimes) EVF slightly more prone to RGB 'tearing' than competitors Image review not separately configurable for EVF and LCD Awkward to navigate between stills and movie playback modes LCD unusually prone to finger prints and smearing (reducing visibility in very bright light) Золотую премию дали!
- According to Sony the translucent mirror reflects 30% of the light to a large 15-point phase detection AF sensor. You have a 1/3EV reduction in light transmission for the sensor.
да, камера получилась интересная начинаю засматриваться как на прогулочный вариант + эксперименты с видео для счастья не хватает 2го колеса и затвора 1/8000 порадовало, что окуляр в/и от экрана отодвинули
Пишут что есть управление диафрагмой во время съемки. ИМХО для любителя автофокуса и дафрагмы достаточно.
Всех поздравляю с отличной камерой! Буду брать, как прогулочный вариант с видео! Все же как красиво рисует родная 35-ка... :yum: И фокус вроде быстрый.
Ну и зачем выпускать практически одинаковые камеры а560, а580, a55 и a53? отличие 55/53 от 580/560 в видоискатели 100% против 95%, аф трекинг, поворотный экран теперь во все стороны крутиться и 10fps против 7fps. Хотя бы матрицы разные поставила, а так мне не понятно.
Да, забыл подписать, что объектив Sony G 35 mm f/1.4 :yum: Жаль, что звука родного нет... может он там тарахтит как трактор
Мало - плохо. Много - тоже оказывается плохо. Берите ту, которая нравиться. Отличий там полно. Чего только стоит фазовый АФ в режиме Видео, ну и цена естественно
Цена в США! Priced at $749 and $649 respectively, the A55 will be available from October, while the A33 will hit the markets earlier, in September. Отвертка сохранена. ISO 100. У А33 небольшой буфер. AF assist lamp - Yes, dedicated lamp - Не, понял, - где? The shorter handgrip may cause problems with anyone with particularly large hands, NP-FW50 is rated for between 330 and 380 images depending on EVF/LCD use - будет ли вертикальная рукоятка со вторым аккумулятором?..
Не понял одного: AF assist lamp - Yes, dedicated lamp - а где она? Отличия между новыми Ахх и Аххх в ВИ и поворотах экранчега?
