Как узнать реальный пробег своей камеры Sony
Тема в разделе "Ремонт и обслуживание", создана пользователем RTI, 17 апр 2013.
  1. Счетчик кадров
    Коллеги, на сайте sonyalpharumors появилась ссылка на метод, который позволит узнать количество кадров сделанные камерой. Причем эта информация записывается в каждый файл - снимок.
    http://tools.science.si/index.php - вот страничка на которой можно узнать количество снимков ( требуется загрузить оригинальный файл из камеры)
    All SONY Alpha DSLR/DSLT and NEX cameras (except A100, A200, A300, A350, A700) are supported.
    There are currently 4 known "tags" in the sony exif makernotes that denote the amount of shutter actuations / images taken. They are all listed below, together with the cameras that use that method.
    V1 - FocusInfo_0x0846
    Cameras that use this method:
    A230 A290 A330 A380 A390 A850 A900
    There is only one counter discovered in this method. It appears to count the number of shutter actuations/images taken.
    Shutter count fields:
    Sony_FocusInfo_0x0846 = A
    Sony_FocusInfo_0x0847 = B
    Sony_FocusInfo_0x0848 = C
    SUM = A + (B * 256) + (C * 65536)
    SUM = (C<< 16) + (B << 8) + A
    V2A - MoreInfo0201_0x014a
    A450 A500 A550
    Sony_MoreInfo0201_0x014a = A
    Sony_MoreInfo0201_0x014b = B
    Sony_MoreInfo0201_0x014c = C
    V2B - MoreInfo0201_0x011b and 0x0125
    A33 A35 A55 A560 A580 NEX-3 NEX-C3 NEX-5
    This is the only method that has two counters.
    The first is for images taken:
    Sony_MoreInfo0201_0x011b = A
    Sony_MoreInfo0201_0x011c = B
    Sony_MoreInfo0201_0x011d = C
    The second is for total shutter actuations:
    Sony_MoreInfo0201_0x0125 = A
    Sony_MoreInfo0201_0x0126 = B
    Sony_MoreInfo0201_0x0127 = C
    The difference is that the camera makes two shutter actuations when shooting in live view mode and takes one image.
    In case of a multi exposure mode (Multi shot ISO, hand held twilight, panorama, HDR) the camera takes multiple images and makes exactly one more shutter actuation as the amount of images taken.
    Note that panoramas can consist out of 50 or more images.
    V3 - Tag9050_0x0032
    A37 A57 A58 A65 A77 A99 NEX-3N NEX-F3 NEX-5N NEX-5R NEX-6 NEX-7
    This is the latest method used by SONY.
    There is only one counter discovered in this method. It counts shutter actuations. With the electronic first curtain shutter the camera makes one shutter actuation per exposure and without it two shutter actuations are required per exposure.
    Sony_Tag9050_0x0032 = A
    Sony_Tag9050_0x0033 = B
    Sony_Tag9050_0x0034 = C
  2. А я только тут заметил, так что спасибо автору! Вечером буду узнавать :)
  3. Buggah
    Buggah Модератор
    9 апр 2008
    IT
    Кемерово
    Полностью соответствует моим прикидкам:
    До замены затвора:
    Detected Model: DSLR-A850
    Shutter actuations made up to file DSC09286.ARW: 49798
    | | | | Sony_FocusInfo_0x0846 = 134
    | | | | Sony_FocusInfo_0x0847 = 194
    | | | | Sony_FocusInfo_0x0848 = 0
    (65536 * 0) + (256 * 194) + 134 = 49798
    После замены затвора:
    Detected Camera model : DSLR-A850
    Shutter actuations made up to file DSC00761.JPG: 885
    | | | | Sony_FocusInfo_0x0846 = 117
    | | | | Sony_FocusInfo_0x0847 = 3
    (65536 * 0) + (256 * 3) + 117 = 885
    Констатирую, что смена затвора счётчик скинула :)
  4. А-850.
    Брал новой по акции в июне 2011.
    Срабатываний затвора -14310. Я думаю, соответствует моим прикидкам.
    Прога нужная, особенно при покупке б/у тушек .
    Когда предлагают камеру 2009 года , да еще с тремя аккумами и заявляют -5000...:mad:
  5. Хочу предложить другой вариант использования программы ExifTool.
    Команда exiftool -a -u -g1 -lang "ru" [имя файла]
    В результате имеем полный EXIF, причем частично на русском языке и ничего вычислять не нужно, все за вас сделает программа.
    В принципе у автора программы по адресу http://www.sno.phy.queensu.ca/~phil/exiftool/ в дистрибутиве программы имеется обширная документация по данному вопросу
    которая включает и список номеров объективов Sony, с учетом объективов сторонних производителей.
  6. Результат полностью подтвердил ожидания
    А850 - 5800 снимков
    А77 - 8100
  7. Rus2000
    Rus2000 Куратор по Ростову
    15 мар 2007
    Ростов-на-Дону
    Удобный способ для А850, А900:
    Скачиваем Exiftool версии 9.28 http://www.sno.phy.queensu.ca/~phil/exiftool/
    В командной строке набираем
    exiftool -"ShutterCount" "d:\example\DSC01234.arw" ("d:\example\DSC01234.arw" - путь и имя проверяемого файла)
    Можно сделать ярлык программы с параметром -"ShutterCount"
    и в окно командной строки затаскивать мышкой сначала этот ярлык, а потом (через пробел) проверяемый файл.
  8. Exiftool просто уже умеет выдавать этот параметр для всех указанных камер. Скоро и другие просмотрщики exif научатся.
    Если надо для анализа, то обычно через ярлык с параметрами все данные сохраняю в текстовый файл. Теперь и этот параметр ("Shutter Count" или "Image Count" в зависимости от камеры) там есть.
  9. А смена затвора по какой причине была?
    И ещё, сколько стоит данная процедура.
    Спрашиваю, так как на 8-мой странице мой пост с количеством срабатываний 113 тыс.
    Как говорится, "готовлю сани летом".
  10. Панорамы и HDR - понятно. А видео - что приплюсовываются все кадры видео?:mad:
    А как объяснить ситуацию: серия из 27 кадров все в одинаковых условиях (в помещении с внешней HVL-20AM, RAW, a77v)
    Sony_Tag9050_0x0032 монотонно увеличивается с шагом 2, на одном кадре шаг = 4 ???:confused:
    При таком шаге формула даст по крайней мере двукратное превышение по сравнению с номером снимка.
    Что кстати и наблюдается судя по данным, приведенним в теме.
    Что-то это как-то странно.:confused:
  11. #94 24 апр 2013 в 17:31 | Как узнать реальный пробег своей камеры Sony | Страница 5
    Сайт, на который я загрузил файл, http://tools.science.si/index.php выдал мне вот такую инфу:
    Detected Camera model : DSLR-A900
    Shutter actuations made up to file DSC02525.JPG: 2548
    | | | | Sony_FocusInfo_0x0846 = 244
    | | | | Sony_FocusInfo_0x0847 = 9
    (65536 * 0) + (256 * 9) + 244 = 2548
    Как понимать эти циферки? Т.е. какой пробег моей камеры?
    Снимок я загрузил с камерным номером DSC02525
    По своей наивности я так и считал, что пробег моей камеры 2525 кадров.
  12. Так и понимайте, нумерация файлов из камеры не говорит о количестве кадров. К вам пришла камера, вы отформатировали карточку флэш и номерация началась с нуля. Всуните карточку где будет 9тыс кадров и камера продолжит считать. Это не раз обсуждалось.
  13. #96 24 апр 2013 в 17:46 | Как узнать реальный пробег своей камеры Sony | Страница 5
    Дык а нафига тогда ссылки на какие-то сайты, которые (как я понял) покажут РЕАЛЬНЫЙ пробег камеры?
    А по поводу карточки с 9 тысячами кадоров вы неправы - я сувал в камеру самые разные карты с чужих камер с пробегами и 10 тысяч и даже 20 тысяч, но моя 900-ка ВСЕГДА показывала свой пробег!
    Повторю вопрос - какой же все-таки пробег моей камеры исходя из той инфы, что выдал сайт по форумной ссылке?
  14. Афтар, сделай сайт со скриптом - заработай трафик) Ибо желающих то много
  15. Мотороллер не мой, я просто разместил объяву (c)
    - - - Updated - - -
    Дык, если Вам не надо и вы так и не поняли - не заходите, не вижу проблем.
  16. Да что ж такое, неужели я так коряво изъясняюсь, что вы не можете понять мой вопрос???
    Я справшиваю, какой пробег мне считать реальным, исходя из вот этой инфы:
    Здесь есть цифра 2548 (что очень близко к тому, что я считаю реальным пробегом) и есть цифра 65563 - неужели это тоже имеет отношение к пробегу?
  17. "
    - тупой гугл переводчик, перевел вот так "Затвор срабатываний сделано до файл DSC02525.JPG: 2548". Вам лень было прочитать первый пост, у вашей камеры пробег 2548.
