  1. #1 13 июл 2008 в 00:20 | Важно DxO Optics Pro / DxO PhotoLab | Страница 121
    Системные требования:
    • DirectX 9.0c-capable system
    Домашняя страница
    Видеоуроки на сайте DxO
  2. [​IMG]
    DxO PhotoLab обновилась до версии 2.0.0 Build 23352
    Date Code 24.10.2018
    Прямая ссылка на скачивание DxO PhotoLab 2.0.0 Build 23352
    The Ultimate Image Processing Software! Designed by and for photographers with exacting standards and a love for beautiful images, DxO PhotoLab 2 offers the most flexible and powerful processing and correction tools on the market. U POINT LOCAL ADJUSTMENT TECHNOLOGY - Perfection is just a few clicks away
    Apply the local adjustments you need using U Point selection assistance technology. No need to waste your time with complicated masks. With U Point technology, your settings are automatically and intelligently applied to all similar points within the area you’ve identified.
    OPTICAL CORRECTIONS - Get the most out of your equipment
    Correct any flaws in your lenses with a single click thanks to our optical correction modules. These modules are the product of years of scientific research by DxO, a company that has pioneered the development of software designed to compensate for optical flaws. DxO’s modules are used by photographers throughout the world.
    PRIME DENOISING TECHNOLOGY - Don’t be afraid of the dark…or high ISO values
    Restore the magic of a starry night, shoot at high speed even in dark conditions, and capture the intimate ambiance of a private concert with the revolutionary denoising technology PRIME. Even when you shoot with very high ISO, you can maintain the same level of detail and colors.
    MANUAL OR AUTOMATIC? - Perfection is just a few clicks away
    In accordance with our approach to photography, all automatic features can be turned off and switched to manual mode. Take control of a number of settings to adjust your corrections to best reflect your artistic intention.
    RAW & MUCH MORE - Image quality before everything else—that’s the DNA of DxO
    Our engineers have always worked to use their technical expertise to perfect your images. Every algorithm and line of code is designed to reach a single goal—harnessing our science to help you achieve your artistic vision.
    CUSTOMIZED PROFILES
    Since the early 2000s, over 42,000 camera/lens combination have been scientifically analyzed in our laboratory to help you get the most out of your equipment. The resulting profiles let DxO PhotoLab 2 automatically and effectively correct any optical flaws in YOUR equipment.
    A SIMPLE AND INTUITIVE WORKFLOW
    DxO PhotoLab 2 gives you access to all the tools that help you enhance your images at any step in your workflow, from retouching all the way to exporting and printing. With the many presets available and the possibility of creating your own, you no longer have to spend hours processing your photos. Instead, you can focus all your energy on your photography. Select, sort, edit, and export your images to social networks or another program using a single intuitive interface. You can even edit your images in Adobe Lightroom and switch back to DxO PhotoLab 2 while still maintaining an optimized workflow.
    Improved U Point technology - Exclusive
    U Point selection assistance technology is fully integrated with DxO PhotoLab via its multi-setting equalizer interface, allowing you to make intuitive and effective local adjustments to complement the software’s automatic corrections.
    DxO PRIME, the ultimate denoising technology - Exclusive
    Push your equipment to the limit thanks to DxO’s industry-leading denoising technology, DxO PRIME. Remove noise from your high ISO images without loosing any details or colors.
    DxO ClearView Plus local contrast optimization - Exclusive
    DxO ClearView brightens the horizon in your images by removing any haze from your landscapes or smog from your urban photos. This exclusive feature increases local contrast after thoroughly analyzing the colormetric components of your image. This technology makes your image more radiant without creating a halo effect around drastic transitions.
    Unparalleled optical corrections - Exclusive
    During the 15 years DxO has been active, over 42,000 lens/camera combinations have been precisely analyzed in our laboratories. Their characteristics have been thoroughly studied to understand how these chains affect the image and to develop corrective profiles specifically for your equipment. Optical flaws like a lack of sharpness, vignetting, chromatic aberrations, and distortion are automatically and effectively corrected.
    PHOTOLIBRARY - NEW
    DxO PhotoLab 2 rounds out the software’s existing filters and image processing tools with the new PhotoLibrary feature.
    The PhotoLibrary makes sorting and organizing images a cinch. Instantly locate the photos you’re searching for thanks to the dynamic interpretation search function, which suggests relevant results on the fly. Keyword search and other features designed to boost your searches will soon be added via free software updates.
    ADVANCED COLOR MANAGEMENT
    DxO PhotoLab 2 now supports .DCP profiles. This feature lets you maintain the same colors even if you switch between several processing and RAW editing programs. If you want to control your entire graphics chain, you can choose to keep the same color signature from one device to another by importing the profiles you create in calibration programs into DxO PhotoLab 2.
    DxO Smart Lighting
    Use the full range of your sensor by revealing new details in underexposed or overexposed areas in your RAW files—even with significant backlighting. Adjust the effect to suit your taste and your vision for the balance between light and dark. In addition, the Selective Tone tool lets you independently adjust different brightness ranges ranging from the darkest to the brightest levels, thereby giving you more freedom and precision when lightening shadows or recovering details in bright areas.
    Spot Weighted Corrections
    With Spot Weighted Corrections, you can adjust your corrections depending on the areas of interest in your photos, such as faces.
    DxO Smart Lighting analyzes and accounts for these areas before applying corrections to the entire image. As a result, your backlit portraits will look brighter while still looking natural.
    ICC profile management
    Use ICC profiles to even out your color renderings and ensure your prints are an exact replicate of your edits.
    Multiple exports
    Export your files in a variety of formats in just one click, or share them to social networks like Facebook, Flickr, etc. DxO PhotoLab performs parallel exports and optimizes your digital development sessions.
    Batch processing
    Edit a RAW file however you want, then apply these edits to a series of images with just one click.
    Fullscreen viewing
    View your images in fullscreen mode and browse your Photo Library without losing your EXIF data display. The viewer function in DxO PhotoLab 2 makes it easier to edit and select your photos in editing and export mode. Use keyboard shortcuts to sort through hundreds of photos in the blink of an eye.
    Moiré removal
    Delete colored artifacts that appear over fine, complex patterns (clothing, grids, etc.).
    DxO PhotoLab 2 + Adobe Lightroom
    Edit your images from Adobe Lightroom in DxO PhotoLab 2, then access them from your catalog without interrupting an optimized workflow.
    Color protection
    Reveal the richness of the details and textures in highly saturated areas of your images.
    Preset DxO parameters: enhance your images with just one click
    DxO PhotoLab includes preset parameters that have been carefully designed to help you achieve all your artistic goals, including portraits, landscapes, black and white photos, single-image HDR, and more. Give your creativity free rein with Ambiance options like desaturation and color filters. Quickly access all available presets, preview the result in a vignette, then apply it directly to your image with just one click.
    Customizable interface
    Create a personalized workspace on one or multiple screens to edit your images in the best possible conditions.
    Direct file access
    You can browse any folder on your computer, another device, a hard drive, or a USB key to directly access your photos.
    Red-eye correction
    This feature detects faces and eyes and automatically corrects red eye. For difficult cases involving profile views of faces, semi-automatic and manual modes let you identify the area you want to correct.
    System Requirements:
    - Intel Core® 2 or AMD Athlon™ 64 X2 or higher (Intel Core® i5 or higher recommended)
    - 4 GB of RAM (8 GB recommended)
    - 4 GB or more of available hard-disk space
    - Microsoft® Windows® 7 (64-bit) with Service Pack 1, Microsoft® Windows® 8.1 (64-bit), or Microsoft® Windows® 10 (64-bit)
    - DirectX 9.0c-capable system
    - OpenCl 1.2-capable graphic card with 1GB of video memory to handle OpenCL acceleration
  3. Похоже что в этой версии наконец то заработал графический процессор.
  4. Обзор: обновление RAW-конвертера DxO PhotoLab 2: что нового?
    DxO, одна из самых инновационных компаний в области работы с цифровыми изображениями, объявила о выпуске DxO PhotoLab 2, крупного обновления программного обеспечения для обработки RAW для Mac и Windows.
    Из новинок DxO PhotoLab 2 предлагает инструмент ClearView Plus, новейшую версию эффективного удаления дымки и средства улучшения контрастности, а также DxO PhotoLibrary, новую функцию управления изображениями и данными, которая позволяет пользователям находить, выбирать, сортировать и просматривать изображения. DxO PhotoLab 2 также поддерживает профили цветов DCP, которые позволяют согласовать цветопередачу в различных популярных программах.
    «Благодаря своим автоматическим функциям и инструментам коррекции DxO PhotoLab стремится помочь фотографам выразить свое художественное видение без ущерба для качества изображения, – говорит Жан-Марк Алексия (Jean-Marc Alexia), вице-президент по маркетингу и стратегии продуктов в DxO Labs. С добавлением инструмента DxO PhotoLibrary, программа DxO PhotoLab 2 теперь переходит на следующий уровень, предоставляя пользователям полный контроль над процессом обработки изображений, от организации фотографий до их экспорта. К концу года этот новый инструмент будет включать дополнительный поиск функции, включая ключевые слова и многие другие критерии».
    Технология U Point: самый эффективный инструмент локальной обработки
    DxO PhotoLab 2 предлагает полное решение для обработки RAW и JPEG на основе оптических поправок из математически установленных лабораторных моделей, а также таких эксклюзивных функций, таких как уникальная технология уменьшения шума PRIME и интеллектуальная оптимизация экспозиции DxO Smart Lighting.
    Чтобы предоставить фотографам все инструменты, необходимые для внесения локальных корректировок, DxO приобрел и интегрировал технологию U Point Nik Software в программу DxO PhotoLab. Эта эксклюзивная технология, которой пользуются миллионы фотографов, позволяет пользователям делать сложные обработки всего за несколько кликов и применять локальные настройки с помощью контрольных точек, уникальной системы эквалайзеров и нескольких инструментов коррекции. DxO PhotoLab – единственное программное обеспечение, в которое полностью интегрирована технология U Point в недеструктивный рабочий процесс обработки RAW.
    DxO ClearView Plus: удаление дымки на новом уровне
    Функция DxO ClearView от DXO PhotoLab – это инструмент, который устраняет туман, дымку и усиливает локальный контраст. Улучшенная функция DxO ClearView Plus в DxO PhotoLab 2 позволяет пользователям делать еще более точные корректировки, не создавая ореол вокруг переходов между светлым и темным.
    Всего за один клик пользователи могут удалить дымку, не создавая неестественного эффекта вокруг объектов, резких краев, мелких деталей или переходов. В сочетании с PRIME, эксклюзивным инструментом для шумоподавления, пользователи могут оптимизировать динамический диапазон изображения при одновременном управлении шумом. Для большей гибкости DxO ClearView Plus можно применять ко всему изображению или только к конкретным областям с помощью местных инструментов настройки.
    DxO PhotoLibrary: полный рабочий процесс создания фотографий
    Инструмент DxO PhotoLibrary предлагает новые функции поиска, выбора, сортировки и отображения изображений. Благодаря функции динамического текстового поля программа делает поиск простым. По мере ввода поискового запроса DxO PhotoLab 2 предлагает все соответствующие интерпретации и отображает те результаты, которые соответствуют личной базе данных пользователя.
    Пользователи могут искать изображения по нескольким критериям, включая параметры съемки (диафрагма, скорость затвора, ISO), имя файла и расширение, дату, когда фотография была сделана, и количество звезд, назначенных фотографии. Результаты поиска отображаются в совершенно новой подвижной и регулируемой сетке виньетки.
    Поддержка цветовых профилей DCP: новые параметры управления цветом в изображениях RAW
    DxO PhotoLab 2 теперь поддерживает профили цветов DCP; это означает, что программа может предоставить цветопередачу, совместимую с программами редактирования фото сторонних разработчиков, такими как Adobe Lightroom и Adobe Camera RAW, а также решения для калибровки цвета камеры, такие как X-Rite ColorChecker Passport Photo и DNG Profile Editor.
    Источник FOTOEXPERTS
    Alex.V, Alikbars, TheCluster и ещё 1-му нравится это.
  5. #2404 22 ноя 2018 в 23:56 | Важно DxO Optics Pro / DxO PhotoLab | Страница 121
    DxO PhotoLab обновилась до версии DxO PhotoLab 2.0.1 Build 23411 Elite
    Date Code 21.11.2018
    Прямая ссылка на скачивание DxO PhotoLab 2.0.1 Build 23411
    • Search History will allow you to access the 5 latest searches done in your PhotoLibrary.
    • Folder Name search criteria: you can now search images from your database by folder name
    • F11 / F12 shortcuts: F11 will switch to Fullscreen mode. F12 will maximize the interface.
    • Bug fix:
    - Panasonic GX-9 files problems with lighting and green color cast
    - Minor bugs
    User Guide
    Release Notes - MAC
    Release Notes - Win
  6. #2405 25 ноя 2018 в 12:48 | Важно DxO Optics Pro / DxO PhotoLab | Страница 121
    Пакет русской локализации DxO PhotoLab 2.0.1 Build 23411 Elite v. 9.2. RU от nktch (Nikitich) от 25.11.18 г.
    Файлы локализации подходят только для этой КОНКРЕТНОЙ версии DxO PhotoLab!!!
    скачать
    зеркало
    Русификатор выложен с ведома и разрешения автора.
    Вид русификации DxO PhotoLab 2.0.1 Build 23411:
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
  7. АlexPol, Ай-яй-яй. Здесь низя такое, а кому надо найдет.
    nauticus нравится это.
  8. Извините. Я-то не в курсах, что есть то, чего нельзя. Прошу извинить.
    Добра...
  9. Правила для пользователей форума нужно смотреть... Там все прописано, что нельзя...
    За 3 года на форуме можно было и потрудиться сделать это.
  10. #2409 6 дек 2018 в 14:26 | Важно DxO Optics Pro / DxO PhotoLab | Страница 121
    DxO PhotoLab обновилась до версии 2.1.0 Build 23440
    Release Notes - MAC
    Release Notes - Win
    User Guide
    Прямая ссылка на скачивание DxO PhotoLab 2.1.0 Build 23440
    Изменения:
    3 New cameras supported:
    - Nikon Z7
    - DJI Mavic 2 PRO
    - FujiFilm X-A5
    • Bux fixes:
    - Application crashed when using local correction tools in some cases
    - Fix regression on Nikon D200 White Balance
    - Fix regression on RAW decoding of Panasonic images shot in high resolution mode
    - Minor bugs
    vega@71 нравится это.
  11. DхO предлагаем рождественский подарок - скидка 30% на все программы.
    DхO PHOTOLAB можно купить за $99,99.
    www.dxo.com/dxo-photolab/
    TheCluster, nauticus и vart нравится это.
  12. #2411 9 дек 2018 в 18:08 | Важно DxO Optics Pro / DxO PhotoLab | Страница 121
    Пакет русской локализации для DxO PhotoLab версии 2.1.0 Build 23440
    v. 9.3. RU от nktch (Nikitich)
    от 09.12.18 г.
    Файлы локализации подходят только для этой КОНКРЕТНОЙ версии DxO PhotoLab - 2.1.0 Build 23440!!!
    скачать
    зеркало
    Скрины русификации:
  13. А в "черную" пятницу скидка была 50% на все. Но все равно дорого. Если заказать сам PHOTOLAB, надстройку со стилями и исправлениями искажений было под 200 евро
    smiserg нравится это.
  14. [​IMG]
    DxO PhotoLab обновилась до версии 2.1.1 Build 23555
    Release Notes - MAC| Release Notes - Win
    User Guide
    New features in DxO PhotoLab 2.1.1:
    • Bux fixes:
    - Unsupported Compressed RAW file from Nikon Z 7
    - Display Error when using DCP profile with special characters
    - Application crashed in some cases of use of search tokens
    - Cannot reach 0 by using the arrows in the Selective Tone settings
    - Minor bugs
    Прямая ссылка на скачивание DxO PhotoLab 2.1.1 Build 23555
    Shep67 и Genisch нравится это.
  15. [​IMG]
    DxO PhotoLab обновилась до версии 2.2.0 Build 23644
    User Guide| Release Notes - MAC| Release Notes - Win
    New features in DxO PhotoLab 2.2:
    • 4 New cameras supported:
    - Nikon Z6
    - Canon EOS-R
    - DJI Mavic 2 ZOOM
    - Canon EOS-M50
    Bux fixes:
    - Some JPG images can take minutes to be loaded in PhotoLab
    - Crash of PhotoLab with some image + caf modules association
    - Missing date of shoot in output dng for Sony
    - Color casts and color renderings issues on some Sony RX100 VI and Olympus EM5 images
    - Minor bugs
    Прямая ссылка на скачивание DxO PhotoLab 2.2.0 Build 23644
  16. #2415 28 мар 2019 в 16:32 | Важно DxO Optics Pro / DxO PhotoLab | Страница 121
    Уважаемые коллеги!
    До 2 апреля DхO PHOTOLAB ELITE EDITION можно купить за $89 (With the code
    APRIL-SAVE-DPL2).
  17. как софтина? имеет смысл к покупке? при наличии С1 версии 9
  18. RulerM
    13 фев 2006
    Saratov, Russia
    Совсем разный софт.
    Я на это смотрю так, что С1 - для печати, DxO - для экрана.
    В обратном применении оба - не очень.
  19. На мой взгляд Luminar 3 обладает большим функционалом( количеством предустановленных фильтров) и стоит дешевле DXO
  20. #2419 5 апр 2019 в 14:14 | Важно DxO Optics Pro / DxO PhotoLab | Страница 121
    DxO PhotoLab обновилась до версии 2.2.2 Build 23730
    User Guide
    DxO PhotoLab 2.2: Support added for the Nikon Z 6 and the Canon EOS R
    PARIS — March 6, 2019 — DxO PhotoLab, DxO’s advanced photo editing software, continues to evolve with its new update to version 2.2. After introducing and improving DxO PhotoLibrary, an image and data management system that lets users search for, select, sort, and display images, DxO PhotoLab 2.2 adds support for four new devices: the Nikon Z 6, the Canon EOS R and EOS M50, and the DJI Mavic 2 Zoom drone.
    More Than 46,000 Camera/Lens Combinations Available
    DxO PhotoLab 2.2 adds no fewer than 3,472 new optical modules to its library, bringing the total number of available combinations to 46,248—among them the recent NIKKOR Z 35mm f/1.8 S and NIKKOR Z 50mm f/1.8 S, as well as the CANON RF 24-105mm F4L and the CANON RF 50mm F1.2. The software also includes modules from the Hasselblad X1D’s range of autofocus lenses specifically designed for high resolution: the Hasselblad XCD 21mm F4, the Hasselblad XCD 30mm F3.5, and the Hasselblad XCD 90mm F3.2. Further, the new version supports the Mavic 2 Zoom, a DJI consumer drone with 24-48mm F2.8-3.8 lenses. Finally, version 2.2 completes its offer for Canon, Nikon, Panasonic, Pentax and Sony with the following modules:
    • Panasonic Leica DG Vario 50-200mm F2.8-4.0 ASPH
    • Pentax-D FA* 50mm F1.4 SDM AW
    • Samyang AF 35mm F2.8 for Sony FE
    • Sigma 105mm F1.4 DG HSM Art for Nikon F
    • Sigma 56mm F1.4 DC DN C for Sony E
    • Tamron SP 35mm F1.8 Di USD (F012) for Sony Alpha
    • Tamron SP 45mm F1.8 Di USD (F013) for Sony Alpha
    • Zeiss Milvus 25mm F1.4 ZE for Canon EF
    • Zeiss Milvus 25mm F1.4 ZF.2 for Nikon F
    • Zeiss Distagon T* 35mm F2 for Nikon F
    • Zeiss Loxia 25mm F2.4 for Sony FE
    These optical modules are designed in DxO’s laboratories according to a proprietary scientific characterization process. They contain all the information about the specificities of thousands of camera/lens combinations. Further, they allow DxO solutions—DxO PhotoLab, DxO FilmPack, and DxO ViewPoint— to automatically correct such optical defects such as distortion, chromatic aberrations, and vignetting with a high level of quality. In addition, DxO PhotoLab is the only software that corrects the lack of sharpness in lenses without otherwise degrading the image. Thanks to its unique know-how, DxO now offers the best optical corrections on the market.
    Go to https://www.dxo.com/dxo-photolab/supported-cameras/ to see the list of equipment that DxO PhotoLab 2.2 supports.
    Price & Availability:
    The ESSENTIAL and ELITE editions of DxO PhotoLab 2.2 (PC and Mac) are immediately available for downloading from DxO website (https://shop.dxo.com) at the following prices:
    GBP:
    * DxO PhotoLab 2.2 ESSENTIAL Edition: £99
    * DxO PhotoLab 2.2 ELITE Edition: £159
    USD:
    * DxO PhotoLab 2.2 ESSENTIAL Edition: $129
    * DxO PhotoLab 2.2 ELITE Edition: $199
    EUR:
    * DxO PhotoLab 2.2 ESSENTIAL Edition: €129
    * DxO PhotoLab 2.2 ELITE Edition: €199
    This update is free of charge for owners of DxO PhotoLab 2. The DxO PhotoLab 2 license does not require a subscription and allows you to install the software on two workstations (DxO PhotoLab 2 ESSENTIAL Edition) or on three workstations (DxO PhotoLab 2 ELITE Edition). Photographers with a version of DxO OpticsPro or of DxO PhotoLab 1 can purchase an update to DxO PhotoLab 2 by logging into their customer account at www.dxo.com. A fully-functional trial version of DxO PhotoLab 2, valid for one month, is available on the DxO website: https://www.dxo.com/dxo-photolab/download/.
    New features in DxO PhotoLab 2.2.2:
    - Hotfix
    Bux fixes:
    - CR3 file format doesn’t create a memory leak anymore
    - Shortcut to display clipping areas of highlights and shadows are fixed
    - Minor bug fixes
    Прямая ссылка на скачивание DxO PhotoLab 2.2.2 Build 23730
  21. #2420 16 апр 2019 в 12:31 | Важно DxO Optics Pro / DxO PhotoLab | Страница 121
    Пакет русской локализации для DxO PhotoLab версии 2.2.2 Build 23730
    от nktch (Nikitich)
    от 16.04.2019 г.
    Файлы локализации подходят только для этой КОНКРЕТНОЙ версии DxO PhotoLab - 2.2.2 Build 23730!!!
    Порядок установки русификатора:
    1. Зайти в каталог с установленной программой ( C:\Program Files\DxO\DxO PhotoLab 2\ ) .
    Скопировать все файлы из папки пакета русификации 'de' в папку 'de' каталога с установленной программой (согласиться с заменой) .
    2. Запустить программу, в меню выбрать немецкий язык: Edite > Preferences... > General > Aplication language 'Deutsch'.
    3. Перезапустить программу.
    скачать
    зеркало
