Неожиданно новый слух http://www.sonyalpharumors.com/sr5-first-images-and-full-specs-of-the-sony-a3500/ Обратите внимание на новый объектив! Camera Type Interchangeable lens digital camera with built-in flash Sony E-mount lenses Image Sensor Type APS-C type (23.2 x 15.4mm), “Exmor” APS HD CMOS sensor Effective no. of Pixels Approx. 20.1 mega pixels Total no. of Pixels Approx. 20.4 mega pixels Anti-Dust System Charge protection coating on, Optical Filter Recording System (Still Image) Recording Format JPEG (DCF Ver. 2.0, Exif Ver.2.3, MPF Baseline compliant), RAW (Sony ARW 2.3 format) Image Size (Aspect Ratio 3:2) L: 5456 x 3632(20M), M: 3872×2576(10M), S: 2736×1824(5M) Image Size (Aspect Ratio 16:9) L: 5456×3064(17M), M: 3872×2176(8.4M), S:2736×1536(4.2M) Image Quality Modes RAW & JPEG, JPEG Fine, JPEG Standard Picture Effects Posterization (Color, B/W), Pop Color, Retro Photo, Partial Color (R,G,B,Y), High Contrast Mono, Toy Camera, Soft High-key, Soft Focus, HDR Painting, Rich-tone Mono, Miniature Creative Style Standard, Vivid, Portrait, Landscape, Sunset, B/W (Contrast (-3 to +3steps), Saturation(-3 to +3steps), Sharpness(-3 to +3steps)) Dynamic Range Off, Dynamic Range Optimizer (Auto/Level), Auto High Dynamic Range: Off, Auto Exposure Difference, Exposure difference Level (1.0-6.0EV, 1.0EV step) Color Space sRGB standard (with sYCC gamut) and Adobe RGB standard compatible with TRILUMINOS™ Color Recording System (Movie) Recording Format AVCHD format Ver. 2.0 compliant, MP4 Video Compression MPEG-4 AVC/H.264, MPEG-4 AVC/H.264 Audio Recording Format Dolby Digital (AC-3) 2ch, MPEG-4 AAC-LC 2ch Recording Media Memory Stick Memory Stick PRO Duo, Memory Stick PRO-HG Duo, Memory Stick XC-HG Duo SD Memory Card SD memory card, SDHC memory card, SDXC memory card White Balance Modes Auto WB, Daylight, Shade, Cloudy, Incandescent, Fluorescent, Flash, C.Tem , C.Filter , Custom Focus System Type Contrast-detection AF*1 Sensitivity Range EV0 to EV20 (ISO100 equivalent with F2.8 lens attached) Focus Modes Autofocus, DMF (Direct Manual Focus)*2 , Manual Focus*2 Autofocus Mode AF-S: Single-shot AF, AF-C: Continuous AF Focus Area Multi Point (25 points) / Center-weighted / Flexible Spot Other Features Tracking Focus, Focus lock, Built-in AF illuminator (Distance: approx. 0.5-3.0m (with E 18-50mm F4-5.6 lens attached)) Exposure Control Metering System Type 1200-zone evaluative metering Sensitivity Range EV0 to EV20 (at ISO100 equivalent with F2.8 lens attached) Metering Modes Multi-segment, Center-weighted, Spot Exposure Modes iAUTO, Superior Auto, Programmed AE (P), Aperture priority (A), Shutter-speed priority (S), Manual (M), Sweep Panorama, Scene Selection Scene Selection Portrait, Landscape, Macro, Sports action, Sunset, Night portrait, Night view, Hand-held Twilight, Anti Motion Blur Exposure Compensation Still images: +/- 3.0EV (1/3EV steps), Movies: +/- 2.0EV (1/3EV steps) Exposure Bracketing With 1/3, 2/3, 1, 2, 3EV increments, 3frames AE Lock AE is locked when the shutter button is half pressed (ON/OFF is available in MENU) ISO Sensitivity Still images: ISO100 to 16000, AUTO (ISO100 to 3200), Movies:ISO100 to 3200 equivalent, AUTO(ISO100 to 3200 equivalent) LCD LCD Monitor Type 7.5cm (3.0-type) wide type TFT Total no. of Dots 230,400 dots Brightness Control Manual (5 steps between -2 and +2), Sunny Weather mode Shutter Type Electronically-controlled, vertical-traverse, focal-plane type Shutter Speeds Still images:1/4000 to 30 sec, Bulb, Movies: 1/4000 to 1/4(1/3 steps), up to 1/30 in AUTO mode Flash Sync. Speed 1/160 sec. Viewfinder Type 0.5cm (0.2type) electronic viewfinder(color) Field of View 100% Magnification Approx. 0.70x with 50mm lens at infinity, -1m Eye Relief Approx. 21mm from the eyepiece, 15mm from the eyepiece frame at -1m Diopter Control -4m to +3.5m
Еще одна ссылка про сабж http://www.sonyalpharumors.com/the-sr5-weekend-rumors-roundup-a3500-leaked-new-fe-lenses-to-come-soon-and-a77ii-and-surprises-too/
Это серия камер, возможно является хитрым планом сони. Любители очень часто не разбираются, зеркалка или беззеркалка. Внешний вид и отстегивающийся объектив, может ввести в заблуждение. А покупка иногда совершается именно по внешности, весу и по цене. Вид как у зеркалки, но при этом ... А вот все остальное пока не известно. Проживет - увидим.
Ну надо же... за сутки не было ни одного комента! Вот это интерес! Вот это внимание! Даже на старшем форуме обсуждают яростнее
Скорее всего из а3000 убрали самые обидные косяки и приделали удешевленный кит. А так как по фото никаких выводов сделать нельзя, то и комментов нет. Фото со стороны экрана до сих пор нигде не появилось, а спереди она как а3000 один в один. Вполне вероятно, с выходом а3500, старый 18-55 снимут с производства, а бу 18-55 подорожают.
Это еще что! В магазине, просто спросив про А3000 - что это, манагер мне безапелляционно ответил: зеркалка Сони! Я, мол, это беззеркалка, с байонетом Е, нет - стоит на своем манагер - это ЗЕРКАЛКА от Сони!
Анонс есть http://www.dpreview.com/news/2014/03/24/sony-australia-releases-a3500-with-new-kit-lens?utm_campaign=internal-link&utm_source=news-list&utm_medium=text&ref=title_0_10 Правда почему-то только для Австралии???
Скорее всего, на снимке макет, или, говоря по-автомобильному "носитель агрегатов" в корпусе прежней тушки. Подождем реальную камеру.
В России уже продается: тут http://www.dns-shop.ru/catalog/i191532/sistemnaya-kamera-sony-alpha-ilce-3500k-black-18-50-mm.html уже пару недель как доступен по 13 990р. и даже с акцией 1500 р. в подарок объектив кстати SEL-1850 f/4-5.6, а именно http://market.yandex.ru/model.xml?modelid=10854194&hid=90613 точно похуже, из него еще и стаб с афтофокусом выкинули кажется.. даже тему про него создавать лениво. Итого, имеем странный набор (особенно учитывая характеристики и оглядываясь на ценник 12 990 р. NEX-3N с SELP1650 в этом же магазине)
Чет непонятный странный зверь.... я кстати надеялся что в эти корпуса т.е большие типо форм фактор зеркалки но под Е они таки запихают стаб, а нефига....
За такие деньги стаб? Ну, что Вы. ) А я надеялся, что туда запихают экран получше и ЭВИ. Но, увы - ничего не изменилось. Кроме смешного объектива в ките.
https://www.sonynex.ru/gallery/image/39397-/ https://www.sonynex.ru/gallery/image/39396-dsc6151/ https://www.sonynex.ru/gallery/image/39395-dsc6150/ https://www.sonynex.ru/gallery/image/39394-dsc6148/ https://www.sonynex.ru/gallery/image/39393-dsc6144/ https://www.sonynex.ru/gallery/image/39392-dsc6143/ https://www.sonynex.ru/gallery/image/39391-dsc6142/ https://www.sonynex.ru/gallery/image/39390-dsc6141/ https://www.sonynex.ru/gallery/image/39389-dsc6140/ https://www.sonynex.ru/gallery/image/39387-dsc6138/ https://www.sonynex.ru/gallery/image/39386-dsc6137/ Несмотря на излишнюю пустоту внутри корпуса, А3500 перегревается при съемке непрерывного видео!!!
Сегодня врезал гнездо под джек 3.5мм для подключения внешнего микрофона. В планах сохранить работу встроенных микрофонов при отключении внешних. Экономия в каждой мелочи-даже капсули микрофонов как в мобильных телефонах мелкого калибра
https://youtu.be/CePFQ8zhYX4 SONY A3500+Самянг14/2,8+Зенитар-М50/1,7 монтаж без какого либо затрагивания картинки
