Собрался тут HDR панорамку собрать... Загрузил исходники (снимал в режиме приоритета диафрагмы с брекетингом в две ступени), так она их не видит как HDR. Пишет, надо в ручном режиме снимать... Раньше, однако, работало... Где логика? Где разум? Чем съёмка в ручном режиме отличается от других режимов? Попробую обмануть зверушку-поправить exif. Надо вот только найти подходящий редактор... Попробовал AnalogExif , что-то не очень.. Есть идеи?
Обещают в 12-й версии реализовать... или взад вернуть? Improved HDR support (Pro version only) HDR in PTGui 11 is based around 'blend planes': at each EV a complete panorama is stitched and blended. Finally the blend planes are merged to an HDR panorama or combined using Exposure Fusion. To work with the new optimum seam placement, the HDR workflow had to change. A problem with the blend plane approach is that the optimum seam will turn out differently for each blend plane. Around the seams, pixels from different bracketed sets would be merged to HDR and this would result in ugly HDR artifacts. To solve this, PTGui 12 reverses the processing pipeline: now each set of linked images is first merged to HDR and then the HDR images are blended (using optimum seam placement) to an HDR panorama. As an additional benefit, PTGui Pro no longer requires HDR panoramas to be taken in manual exposure (M) mode. This is because each set of bracketed images will be separately merged to HDR. Better yet, the number or sequence of bracketed images doesn't even have to be constant anymore. Just tell PTGui which images are bracketed sets by linking them. It's even possible to generate HDR panoramas from single, non-bracketed images taken in automatic exposure mode. In fact, PTGui Pro 12 no longer distinguishes between HDR and non-HDR panoramas, every panorama is HDR! The stitching pipeline uses floating point data internally and any panorama, bracketed or not, can be rendered to HDR formats such as OpenEXR.
HDR софт (за редким исключением) весьма агрессивный. PTGui ранней версии (которая ещё работала с брекетингом) была весьма деликатна в части HDR...
Я сначала в софте для hdr с одинаковыми настройками снимки делаю, потом в фотошопе свожу с кадрами с нормальной экспозицией, размытие порядка 25-40%. Получаю кадры с расширенным диапазоном без агрессивного hdr. А потом уже панорамы свожу. Заморочено конечно, зато проблем с софтом не возникает
