интересная камера Large 4/3" "Best-in-Class" MOS imager with fast image scanning and optical and low pass filters that eliminate aliasing and moire while minimizing skew запись в 1080 (60i, 50i, 30p, 25p and 24p native) и 720 (60p, 50p, 30p, 25p and 24p native, utilizing AVCCAM's highest-quality PH mode (maximum 24Mbps) Variable frame rates in 24P, 30P and 25P in1080, up to 60P or 50p dependent on 60Hz or 50Hz mode Несжатый поток 4:2:2, 8 Bit через HD-SDI и HDMI Six built-in, customizable Scene Files that can be utilized for instant, easy matching between multiple cameras Built-in gamma curves including HD Norm, HD Low and High, Cine-like D, Cine-like V, B.Stretch Four selectable color matrices including Norm 1 and Norm 2, Fluorescent and Cinelike Color Phase and Saturation, Pedestal and Detail image control Two card slots that support continuous (relay) recording. Relay recording means that with two 32GB SDHC cards you can record for 6 hours with automatic clip spanning across the two cards SDXC Card compatibility -- with a 64GB SDXC card, you can record for 12 hours in PH Mode, and 48 hours in HG Mode HD Video and Full Audio monitoring during record and playback with high-quality audio pre-amps at the input
интересно, эта камера поступит в продажу уже через пару недель и насколько быстро отреагирует сони и выпустит конкурента...
