Metz mecablitz 26 AF-1
Тема в разделе "Аксессуары для Sony NEX", создана пользователем dmitzz, 9 окт 2014.
  1. #1 9 окт 2014 в 10:53 | Metz mecablitz 26 AF-1
    [​IMG] [​IMG] [​IMG] [​IMG]
    A compact all-rounder that is setting new standards.
    Despite its compact size – it even fits in a shirt pocket – the new mecablitz 26 AF-1 digital boasts comprehensive features. The flash output impresses with a guide number of 26 for ISO 100/21° and 85mm, and outperforms integrated flashes. Its handy format makes it the ideal holiday companion, particularly suited to compact cameras with flash shoes. Adjustments can be set using the function keys – ideal for flash novices who expect nothing less than perfect illumination. The ingenious design enables the reflector to be rotated for an indirect flash. Together with the integrated wide angle diffuser, the mecablitz 26 AF-1 digital allows sufficient creative scope for inventive illumination – for shooting videos, too. Because an additional two-level adjustable high output LED permanent light with up to 30 Lux lights up even motion picture photography.
    The use of the product is intended for the illumination of photo shootings. It is not suitable for domestic room illumination.
    High max. guide number 26 for ISO 100/21° and 85 mm
    90° vertical bounce facility
    Simple operating concept
    Integrated wide-angle diffuser for 24 mm illumination
    Flash readiness indicator and correct exposure display on unit and on camera ***
    Status LED
    AF-assist light on Video LED
    Automatic unit shut-off (flash mode)
    Metal base* with quick lock
    TTL flash mode (digital only)
    1st and 2nd shutter curtain synchronisation***
    Automatic fill-in flash ***
    High performance LED
    30 Lux/ 1 m
    2 stage adjustable
    Sony Multi Interface version:
    ADI flash mode / pre-flash TTL
    ADI remote mode*
    2 × AAA alkaline-magnesium batteries
    2 × AAA NiMH rechargeable batterie
    *Slave mode
    *** Functions depend upon camera being used
  2. #2 9 окт 2014 в 10:54 | Metz mecablitz 26 AF-1
    Интересно будет, по какой цене ее выставят.
    UP:
    рекомендованная цена 100 евро.
