Всё о Sony DSLR-A900 или Есть FF !!!
Тема в разделе "SONY с байонетом А", создана пользователем colorIT, 9 сен 2008.
  1. #1 9 сен 2008 в 16:42 | Всё о Sony DSLR-A900 или Есть FF !!!
    [​IMG] [​IMG]
    http://www.dpreview.com/news/0809/08090902sonyalpha900.asp
    • 24.6 MP 35mm format full-frame CMOS sensor (highest res in class)
    • SteadyShot INSIDE full frame image sensor shift stabilization (world first)
    • High Speed Dual Bionz processors
    • Eye-level glass Penta-prism OVF, 100% coverage, 0.74x magnification
    • 9 point AF with 10 assist points, center dual-cross AF w/2.8 sensor
    • 5 frames per second burst, newly developed mirror box
    • Intelligent Preview Function
    • 3 User programmable custom memory modes on mode dial
    • Advanced Dynamic Range Optimizer (5 step selectable)
    • 40 segment honeycomb metering
    • 3.0" 921K pixel Photo Quality (270 dpi) LCD display, 100% coverage
    • Direct HDMI output
    • ISO 200-3200 (ISO 100-6400 expanded range)
    • User interchangeable focusing screens (3 options)
    • CF Type I/II and MS slots, LI-ION battery, STAMINA 880 shots
    • Weight 850g (without battery, card, accs)
    • New Image Data Converter SR software (includes vignetting control)
    • New Vertical Grip
    • Supplied with wireless remote control
    • Magnesium Alloy body and rubber seals for dust and moisture resistance
    • AF micro adjustment
    • $2999.99 body price; available late October 2008
    http://www.alphamountworld.com/previews/sony-a900-dslr-hands-on-preview
    http://www.alphamountworld.com/image-samples/sony-a900-sample-image-gallery
    куча семплов!
    This gallery contains images from a production sample Sony A900 with firmware Version 1.00. I wanted to have a separate gallery so that I could update images here while testing the camera and writing the final review. I will consider requests for images from a particular lens or with certain exposure values. However, please understand that I may not be able to honor all requests, as I am limited in my lens catalog and time with the A900 itself. I have used lenses from both Sony and Minolta for some images in this gallery, the images are noted when you mouse over them.
    http://www.alphamountworld.com/models/a900
    Рекламное видео на закачку!(12Mb)
    link A900 video
    Обзор А900 на 3dnews. Первая часть.
    Sony Alpha DSLR-A900 Service Manual v 1.2 скачать
  2. вопрос номер один:
    какая ISO полностью рабочая? :)
  3. Для каждого своя, как обычно. ;) Хоть там и ресайзы, на мой вкус и 3200 без шумодава вполне терпимые.
  4. #4 9 сен 2008 в 16:53 | Всё о Sony DSLR-A900 или Есть FF !!!
    Из плохих новостей
    Похоже проблема виньетирования серьезно стоит на ФФ сенсоре с SSS
    Все таки чтото бесполезное похоже
    Скромненько :(
    Ну и изюма вроде как большого нет
  5. А вот немного изюма
    After pressing the depth of field preview button, the camera “grabs” a RAW preview image which is processed and displayed on the LCD screen. You can then fine tune white balance, determine the best level and effect of dynamic range optimization, adjust exposure compensation and check histogram data, all before you actually take the picture. Preview images are not recorded on the camera’s memory card, thus saving capacity.
    + можно фокусировочные экраны менять самостоятельно (ура!)
  6. Поддерживаю вопрос номер один!
  7. вот теперь те, кто помнит только кроп, узнают проблему виньетирования,
    да и ХА полезут по-новому, более зло чем на А100-700
  8. Noise reduction off option in the main menu
    User changeable focusing screens
    Micro auto focus control for up to 30 different lenses
    Intelligent Preview technology
    Bracketing up to 2 full stops
    Improved build quality (360 degree magnesium body panels)
    Improved Battery life with the Lithium NP-FM500H (880 shots)
    Compatibility with APS-C specific lenses in the APS-C crop mode
  9. фига себе разрешение!!!!!
  10. а по поводу Intelligent Preview, как и предпологали многие - логическое продолжение того, как было реализовано на пленочной семерке.
    Можно подбирать параметры, в реальном времени будет изменяться картинка и диаграммы
  11. #11 9 сен 2008 в 17:01 | Всё о Sony DSLR-A900 или Есть FF !!!
    AF micro adjustment
    йес!
  12. теперь у продавцов должен появиться обязательный пункт объектив виньетирует/нет на А900 :)
  13. это изюм? :D :yum:
    alext71 нравится это.
  14. А что же это по-вашему? По мне так очень даже изюм - давно ждём :yum: :)
  15. Начали выпуск ФФ и хорошо! Дальше будут модернизировать и т.д. "Были бы кости, а мясо нарастёт!" :)
  16. ISO в видоискателе и на экранчике отсутствует?
  17. #18 9 сен 2008 в 17:16 | Всё о Sony DSLR-A900 или Есть FF !!!
    на верхнем? - насколько я понял, только если подержать кнопку ISO
  18. а где про цену 70-400?
  19. оправданы ожидания
    ждем нормальных самплов
